RB 5.2.2.0
Kroakster
Just downloaded latest version 5.2.2.0 and possible bug...
If you click Mute Monitor at top of screen it mutes OK, but then cannot UN-mute again'    :'(
That's odd... Just checked it here and it works OK. Can you please give more information on it, does it occur again if you restart RadioBOSS or Windows?
nelson c
Attached here I found several bugs.
The present day is version 5.2.2, appeared when you drag songs from Windows Explorer to a playlist RB.
But everything worked as it should.
  • Desktop.rar
nelson c
more reports.
Some were because you try to move a track and was doing cueing.
One sometimes the program hung completely and restart.
  • Desktop.rar
Excellent job on 5.2.2.0 Dmitry.  I haven't had a chance yet to check it all out, but by the email I got last night, the new one looks promising.
more reports.
OK, thanks, will take a look at those reports.
Thanks! This update targets bug fixes and minor improvements mostly...
I figured it out yesterday and found out the output to encoders is just for the mic side of it.
Yes. If you want everything to be broadcaster directly to encoders (without using sound card) then select "No sound" in Settings->Playback for the Main soundcard.
