refresh of scheduler window
ormston
i still think it would be good to have a refresh of the scheduler window, either automatic, or have a command to do it.
when my groups disable and enable, they scheduler window does not show the current state, until i click on the enable checkbox twice
i know its a minor thing, its only 2 clicks, but it would be so smooth and cool to have the scheduler window reflect the current state automatically. as i said it could be a command that it could schedule such as "multiple event : enablegroupday, refresh" or just make it automatic so the scheduler window always only shows the things that are enabled without having to deselect the enabled checkbox and reselect enabled checkbox
It's always refreshed automatically, if you have a situation when this does not happen - can you please provide some details. Running "enablegroup" or "disablegroup" events here always correctly updates the list state.
ormston
i will send screen shots at the next opportunity, i am just wondering if its because it am running windows 7 not windows 10
ormston
seems like if i have the group collapsed and then an enablegroup command runs, it doesn't expand the group and show the items as enabled, as i said before it is minor, i can just click on enabled checkbox twice and i am back to normal
ormston
OK here is an example, the command enablegroup night HAS ran and IS working, but the scheduler window does NOT show it
until i click on enabled and the then click on enabled again, then it shows
so it NOT the functionality that is the issue, it DOES enable the group and run the events, just the scheduler window does not refresh until i forced it
The enablegroup event is not supposed to expand the group, it only changed the event states from Disabled to Enabled. If a collapsed group is disabled, then enablegroup command runs - after the group is expanded, events in there are in the Enabled state - as they should be.
I see. The problem here is that you use event filters and those are not updated when event states change. We'll fix that, thank you for the details.
