Repeating playlist
RadioTeAroha
We set up a playlist on RadioBoss Cloud with a few music tracks, a few station IDs and a couple of community notices. For some bizarre reason the scheduled playlist repeats itself when finished until we manually stop it. It happens with only 1 of 30 playlists we have that are set up. Any idea what the problem could be? Attached is a screenshot of our schedule settings.
After all scheduled tracks are played, it will continue playing other tracks from the playlist window, and scheduled tracks will be removed. One possibility for it to repeat is that there are no other tracks for it to play. You can check the contents of the playlist window in the Overview tab.
This is a recent problem that started happening about 2 weeks ago. Surely when a playlist has finished, the system should revert back to our random playlist (as it used to) where we have over 1,500 tracks. We use RadioBoss cloud - stream8371
We did not issue any updates to the modules which handle playlist playback in the past month - so nothing was changed in this regard. You can open the Overview tab and see what it's playing, what scheduled events are inserted into the queue etc.
