Running under Crossover - sound issues
knobby
Hi,
I've just installed RadioBOSS 5.8.5 under Crossover (v18.5) on my iMac and I'm having some sound issues. It works OK until I do anything else on my iMac (open other software, click on a link on a webpage in my browser, etc) then the sound becomes choppy & starts to crackle and distort. This continues until I either pause or stop the song that's playing. When I restart the song the sound is fine until I do something else then it goes again.
I've tried increasing the buffer but that made no difference.
My iMac is quite old - it's a 3.06Ghz Intel Core 2 Duo with 12Gb RAM. Could this be the issue?
TIA
We don't really test it under emulation. The version you use (5.8) is also very old. I don't think we can offer you any assistance with the matter.
We did not test it, so I can't tell. You can try the demo version to see if it works.
