schedule and fadeout
karahan
Hi. I have two problems.
We broadcast the News every single hour.When the News goes on air,the previous song is directly cut.However ve would like the previous song to end by fade-out right before the News,instead of being cut.
How can be program that?
I also would like to schedule a band-program or a playlist at different times of the day such as 13:10, 15:20 , 22:35 (different hours and minutes on the same day) How can I do that?
Thanks.
You should use Sweepers to make it find a track that will end right before the event: https://manual.djsoft.net/radioboss/en/sweepers.htm
Currently multiple start times for an events are not possible (we plan on adding it in the future). Currently, the only option is to create three events.
I tr?ed use Sweepers.when I use sweepers,News goes on air,the previous Sweepers is directly cut.
We would like the previous song to end by fade-out right before the News,instead of being cut.  :(
The sweeper will be faded out according to the crossfade settings: https://manual.djsoft.net/radioboss/en/crossfades.htm
