I understand...let me restate things a bit differently. I find scheduling Events by DTMF or by DTMF only can be a bit confusing. Let me give you an example of what I am doing. Our network sends the DTMF tone "03" to indicate a :60sec break that affiliates can utilize locally. This break may or not happen during a given hour depending on network programming. The break can also happen up to two times in a given hour. Most hours IF the break occurs, it is usually at hh:29:00 and hh:58:45 most of the time. Note: there are a couple hours where the hh:29:00 break may float between hh:25:00 and hh:35:00 after the hour. I know this is confusing, hopefully you figured it out. Anyway, here's how I'm scheduling it.
In Configuration/DTMF I have DTMF checking frame set at 10 minutes.
I have one scheduled event to start by DTMF "03" only at all hours, 35 minutes and 0 Seconds.
I have another scheduled event to start by DTMF "03" only at all hours, 5 minutes and 45 seconds.
This pretty much covers the few floaters and the fixed times if an when they occur. This gets a bit confusing when explaining this to others that use the network. They get confused when the network says that the break may occur at 29 or 58:45 but when scheduling the event times are different.
I would like to be able to schedule the event at let's say at hh:29:00 and then have the option in the particular event to add a start and stop window time to look for the DTMF tone. Or keep things the way they are, but have the DTMF checking frame time be so that if I set it for 10mins, the scheduled event that is scheduled to play by DTMF ONLY at hh:29:00 can play between 10mins prior and 10mins after the scheduled time. Does this make sense?
Maybe I'm crazy here and being too picky. I don't know, I'll leave that up to you! I do thank you for the time and effort that you put into this program!! Thanks
mike
