silence detector
radium98
can the next version of radio caster have a silence detector alarm send pm or call via sms if a phone is attached or simply pm the time of cut and if it is reconnect ?
thanks
radium98
ok thanks you , will wait for the adding , i just give some help , but i did not use it , only idea and support .One more thing will you in next major rb update make the now playing txt file go blank when no playing current song after say 30 seconds of dead air , so the rds go to what is keep inside
In the current version, the nowplaying file is cleared when there's nothing playing.
RadioLogger works great via email. I wish it could send a text instead or have a choice between the two.
Sending an SMS has a price. We'd need to partner with some SMS service for this and also add a way for customers to purchase SMS credits or include them in the software price.
