Start Stop
perezjos
I have a question about the start / stop tags in Track tool. I have a file for the current month dates. I record all the dates for the month in a long file and then I set manually the start/stop tags everyday using the track library. Of course I could create a set of files for each day from the master , but I was wondering if I could have an example updating the database fields "cuein" "cueout" as I use sqlite to store the extra track information or is it easier to use APEv2 file tag instead for writing some automation ?
Many thanks
Jose
If you want to update them using your own software then you can use any database access tools and programming languages to do so.
