Strange gain Level bug ! Level moves by itself to any value between -inf to +31 dB and becomes RED !
Since a few days i have a strange gain level bug, i never faced before... the slider moves by itself to any value between -inf to +31 dB and the level indicator turns RED...
See attached snapshot !
I have absolutely no idea why it does that, and where it comes from...
AutoAmp is Off, ReplayGain is Off, Gap Killer is off
when it does that bug, and when the level indicator turns red, i can see the slider move to any value it can chose ! incredible !
is there a ghost in my radioBoss app ? LOL
THanks for your help,
FRED
Level is changed (and becomes red) when you press the MIC button (or MIC is enabled using API).
Maybe ! but that's not the case in my situation... even the soundcard is disabled on my laptop... so there can't be any output available (mic or Line !)
And i don't use API !
i've checked avrything is off...
So, the mystery is still entire...
Regards,
FRED
Another thing to check is your file type in options You might have a DB reduction on that, which might do it. You can increase and reduce volumes on these file types. I am not suggesting this is your problem but its worth a look if this continues after following Dimitris advice
