Teaser problem
nelson c
Dmitry this is still happening since 6.3.
I don't know what I can contribute to this topic. :)
Edit: Looking at the topic now I see that it is even older
To confirm, when does it happen? When the teaser is being followed by a container item?
I'm doing tests and it happens every time.
It does not depend on what precedes or closes it.
I disabled all mixing for the Teaser file type and it didn't solve either
You should check crossfade settings for Container file type too - maybe set "Override previous mix" to zero. I checked the bugtracker and looks like we were never able to reproduce it here. I guess a specific combination of settings leads to the bug.
This is my fader setup for teaser. I tried deactivating that without success, the teaser cuts off at the moment when the end file should play. The end file lasts 10 seconds, but cuts off between the 1st and 3rd second of duration. Not always in the same part, and the cut is abrupt without a fader
I just copied the profile file to my test PC (Do not restore backup) and this does not happen there. Which is even stranger, I don't know what else I can contribute about this.
It also doesn't happen here, so currently it wouldn't be possible to fix it. Does it always happen, or it's random?
One thing - enable "Logging - Create Teaser log" in Advanced Settings, wait for it to happen, then send the log (open settings folder, Logs subfolder) - maybe it'll provide some clues.
I only saw that it worked fine on my Air PC once, but nothing had changed. I would say 99% of the time.
I will enable the log
Code:
[ 441535718] TEASER=M:\Mi musica\Archivos Radio\Jingles\Teaser\Apertura|M:\Mi musica\Archivos Radio\Jingles\Teaser\Transicion|M:\Mi musica\Archivos Radio\Jingles\Teaser\Cierre|F|10|R:\Listas Radio\Listas De Reproduccion\AIRE M1.M3U|3|R|10000|R|1Val-Lanz%3A+Alta%09Val-Lanz%3A+Media
[ 441535718] TL_GNT-In
[ 441535765] TL_GNT-Out. FN = M:\Mi musica\Tainy - UN DIA (ONE DAY).flac
[ 441535875] TL-M
[ 441535890] TL-T
[ 441535890] TL_GNT-In
[ 441536000] TL_GNT-Out. FN = M:\Mi musica\Abraham Mateo - Bora Bora.flac
[ 441536140] TL-M
[ 441536140] TL-T
[ 441536140] TL_GNT-In
[ 441536156] TL_GNT-Out. FN = M:\Mi musica\Trueno - TRANKY FUNKY.flac
[ 441536281] TL-M
[ 441536281] TL-E
[ 441536281] TL-Done
[ 441545156] S-NextIn
[ 441545171] NC-Finished
[ 441545171] S-NextOut
[ 441554656] S-NextIn
[ 441554656] NC-Finished
[ 441554656] S-NextOut
[ 441555000] S-NextIn
[ 441555000] NC-Finished
[ 441555000] S-NextOut
[ 441564484] S-NextIn
[ 441564484] NC-Finished
[ 441564484] S-NextOut
[ 441564843] S-NextIn
[ 441564843] NC-Finished
[ 441564843] S-NextOut
[ 441574328] S-NextIn
[ 441574328] NC-Finished
[ 441574328] S-NextOut
[ 441574640] S-ReleaseIn
[ 441574640] S-ReleaseOut
