Temp Screen
Hi Dmitry.
Thank you for all your work on RadioBOSS. It just keeps getting better.
Some partner stations in Asia have asked me to ask you about the Temp screen.
For many of them, they only have the one computer, and they build their playlists in the Temp screen.
Of course, if they do that, all listening must be done via pre-listen. However, it's easy to make the mistake of pushing the play button...and then the Temp screen is live to air (oops!)
Is there any way we can disconnect the Temp screen from the play buttons, so that it operates on pre-listen only? I think this was the way RB used to be configured.
Thanks for your help.
I agree - an option to make a playlist tab non-playable will be added in one of the next updates.
