Conway said:
Is there any way to have the time announce the minutes only and not the hour? Something like 'it's 20 after the hour' or 'it's the top of the hour'.. Makes it much more relevant to all time zones listening in.
There are time zones that differ by 30 minutes - so this will still not work everywhere
You can do it using the filename macro feature: http://manual.djsoft.net/radioboss/en/scheduler_options.htm
1. Record the files for all the minutes you want to announce. Name them so that they include the minute in the file name, e.g.
minute20.mp3 for 20-th minute of the hour. Place all those files in the folder, for instance,
C:\Time.
2. Create a scheduled event(s) that will launch when you need to announce the minutes. In the Filename field enter the following:
C:\Time\minute?nn.mp3 - this way it will select the appropriate minute file from the folder.
