visual suggestions
xzsaimon16
Hello greetings from Venezuela. I am a radio lover and I spend a lot of time researching and testing radio software and I love radioboss.
I have a couple of suggestions for the RadioBoss
* I suggest: Place a flash in the tabs that are playing, example: When playing the main list, a flash is shown in its tab. It would also be great to do it with cart wall. With this we will have a visual warning to know in which tab something is reproduced.
*make improvements in the intro and outro marks, since sometimes the track waveform is not shown in the "on air" display mode.
* It is possible to add a mark similar to the intro and the outro, but to mark an entry and exit point within the song, that is: a song that has an instrumental part in which live voiceover can be done. This is very useful for music radios.
How does it differ from the intro/outro?
Answered to the duplicate post here: https://www.djsoft.net/community/threads/radioboss-6-2-beta.7989/post-39427
¿En qué se diferencia de la intro/outro?
Respondió a la publicación duplicada aquí: https://www.djsoft.net/community/threads/radioboss-6-2-beta.7989/post-39427
I mean a mark where the announcer (live) can see where in the song (instrumental) he can speak. this is very useful for radio stations that use only songs.
the brand can not be exactly as it is in the image you send. It may be so:
It already shows this - the bar appear above the "Now playing" with countdown. The amount of time is Outro of the playing track + Intro of the following track.
I know what you mean.
but you are not understanding me hehehe
Maybe. If you mean marking instrumental parts mid-tracks, I don't think this is really practical because it's a lot of work to manually set all those places for all tracks.
