Voice Meeter mic issue?
Ron
Input error: 37 (No description) I don't know why RB is doing this but on voice meeter it says that. Also voice meeter wont come through this at all its weird.
Try unchecking the "Event driven" checkbox in the device setup. Also post a screenshot how the device is set up in RadioBOSS.
WBGS-Founder said:
i don't know its working now don't have waspi on XP or is there a way to do so?
Under Windows XP the "Error 37" means that another application already using the same device (Voicemeeter virtual card in your case). It's not a bug in RadioBOSS - it just reports to you that the device is not available.
WBGS-Founder said:
so how do I free this up? I keep getting this issue?
1. Close all other programs which use this device.
2. In RadioBOSS - check Input settings and make sure that you didn't select this device multiple times (e.g. for MIC and for Input 1) - the device should be selected only once.
