voicetracking player problem and Schudler hours problem
bobby
Hey djsoft
the voicetracker player on the newer version of radioboss has some bugs in it
everytime i am done recording my voicetrack and then when i hit the play button to preview my voicetrack nothing happens at all
so can you guys fix this problem please
and everytime i try to schulde hours, like 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14 and 15 hours
those hours numbers do not work at all on this newer version of radioboss
so can you fix that problem also please
thanks
1) Voice track plays on the "Preview output" device, as set in the RadioBOSS's playback settings. you should check if the settings are correct.
2) You should check if other settings are correct: week days, date. I did a quick test and "hours" worked fine.
