Get data with php
nelson c
Hi, can someone help me on how is how to extract data from a structure like:
Code:
<CurrentTrack>
<TRACK ARTIST="Inna Ft. Yandel" TITLE="In Your Eyes"
I tried this code but not working
Code:
$xmls = $can . ':' . $PuertoRB . '/?pass=' . $PassRB . '&action=playbackinfo';
$url = file_get_contents($xmls);
$xml = simplexml_load_string($url);
foreach ($xml->TITLE as $cancion)
I think you incorrectly use the $xml variable.
You should use $xml->TRACK, like this:
Code:
$title = $xml->TRACK[0]['TITLE'];
I have other more and more technical consultation.
I'm doing a web remote control to radiboss.
For now the list changes are to be made to update the page.
for that reason, to show the track of the "before" panel, I need to save to the server somehow.
It is the best way using two temporary files?
Thanks Dmitry for your response.  :)
Your code seems to be logical, but it shows nothing.
Already achieved! :). code that works is as follows:
Code:
$title = $xml->CurrentTrack[0]->TRACK[0]['TITLE'];
Yes, using temporary files is OK. Another way is to store it in the database.
