• English
  • Deutsch
  • Español
  • Русский
RadioBOSS box
Author Topic: RadioBOSS Cloud [beta]  (Read 108251 times)
  • Administrator
    • http://www.djsoft.net
Re: RadioBOSS Cloud [beta]
« Reply #150 on: February 22, 2019, 05:33:15 AM »
Issue: When I stopped the radio-player (playlist) with 4 minutes of silence, it didn't generated any email error report for us.
This is by design. It only detects silence when it supposed to be playing. For instance, an incorrect scheduled event may clear the playlist and do not load anything to play. In this case, it will detect the silence. But if you press the Stop button, the player is not expected to play anything, and the silence detector is paused too.
1) The reports can not be generated if you use a large amount of data. For example: If we generate a monthly report, the server gives a time out error. (probably because it takes to long to load)
Yes, this is a bug and will be fixed shortly.
2) It would be great if the generated report is automatically saved with the station name and dates the report is generated for. If I want to generate 4 reports from 4 different days, all reports will be saved as "report". It would be great if it would be for example: "[Station Name] + [Date Reports Generated]" WKOM Radio report 2019-2-2_2019-2-8
Yes, we'll change the filename to include dates, thank you for the suggestion.
3) Would it be possible to publish somewhere the headers of the reports used in CSV or export the reports with headers?
What should be included in the header?
4) It would be Super if you can ad a custom field with info in -> Media -> File Manager -> Tracks ->Tag Editor which will be exported in the report as-well. Specially for notes in regards the tracks or spots being played.
This is something we have planned for the future.
5) Would it be possible in the future to make a selection WHAT the reports are exporting. It's a small thing to delete the info not needed, but it would save time and CPU if you could pre-select the info WHAT you like to export in a report.
The performance is not an issue here, mainly because we have plenty of processing power available, and number of fields really does not affect the speed anyway (1 field vs. 10 fields is only about 5% faster).
6) Export functionality in ZIP?
What is the purpose?
For the rest: We LOVE the way RadioBoss Cloud works!! Impatiently we wait for future developments. We are running 4 RB Clouds for 3 FM stations and 1 AM Station in Metropolitan areas without any Flaws!!
Thank you very much for the good words!
  • Administrator
« Reply #151 on: February 22, 2019, 05:34:47 AM »
I received the error email, 3 hrs and 3 minutes later. What would have been way to late.
I suppose the error email was about some other error, not about the silence (I have the silence thing explained in the previous post). You can see all errors and other events in the Log. The errors are marked in red.
Radio Radio
« Reply #152 on: February 23, 2019, 12:22:47 AM »
Quote from: WKOM on February 19, 2019, 02:06:48 AM
Answer:
For example "what" column name is exported. In my csv for example it exports several columns, most of them I can explain like date, album name etc. However my last column shows me a 2 or 3 (mainly 3) and I have no clue where this comes from or is related to. Also if the custom field can be exported (or an additional custom field can be created and exported, than you can add on additional information for BMI (who requires sometimes explanation why a certain file is a PSA and not to be billed in copyrights. This probably takes place in every US based regular commercial terrestrial station 5/6 x a day.) Also with a custom field in export, additional info can be used when uploading spots, bumpers etc in how long or till when certain spots, bumpers, can be played. Additional info like spot pricing. A simple comma separated field, which can be exported in 1 column, could be used for many reasons. from billing to reporting/logging to professional programs used in terrestrial radio. Software like marketron, sage (quickbooks) etc etc. Right now, if I export the csn file, I need to find all info (like music, bumpers, jingles etc. what i do NOT use. (a 24/7 station plays roughly 2-3 thousand songs a month + thousands of bumpers and jingles and FX etc. THAN I need to sort the Spots, THAN I need to change the headers exactly to HOW my billing software, or logging software like to see the CSV headers.
As you have seen my other questions, IF we could choose which headers could be exported AND manipulate the HEADER names to be exported. AND the exported file will include the headers, THAN there can be a 1 click automated process starting from Cloud Player Report Export to almost ALL professional billing and logging software in terrestrial radio world. With this functionality you have created a large gap in all available professional radio player-content placement software on the market.
I am managing all together 6 stations, all of them are using RadioBoss Cloud because of the easy of use AND cloud functionality. What you guys have developed is JUSt different enough than other cloud players and professional software suppliers to serve the largest small and mid terrestrial market in North America, who have all more or less the same problem. We would even pay for the development if it would be possible.
Quote from: WKOM on February 19, 2019, 10:06:03 AM
Question: I understand, make sense! However, it would be great that users can test this somewhere somehow, so they can set up additional functionalities or know its working and can be used with third party software like forward email to text, for emergency handling.
Answer: Processing! if the column headers could be manipulated in custom fields, than downloading the reports could be used 1-on-1 with for example google share a drive into auto billing, reporting, logging and avadavis software. Zip files can be uploaded automatically in the software named above. Also there are several firewall programs used by prof terrestrial stations and/or virus software which see csv downloads as dangerous and prevent them from downloading. Server operated email clients as-well. Zip files are not been stopped by them.
  • Administrator
« Reply #153 on: February 23, 2019, 11:19:43 AM »
RadioBOSS Cloud 0.6.0 beta
  • Widgets code improved to allow installing multiple widgets of the same type on one web page
  • Improved the look of auto-generated radio station page
  • Downloaded reports file name now includes the report period
  • Fixed a bug when report was not downloaded because of timeout
Steffen Schultz
    • Powerradio4u
« Reply #154 on: February 23, 2019, 11:51:45 AM »
In the widget code there is now a random number in the div ID and as part of the JS URLs. Is it correct that the number can be random, but needs to match within the same widget for Div ID and URL? I'm asking this in order to properly update my CMS plugin.
Steffen
  • Administrator
« Reply #155 on: February 25, 2019, 04:13:11 AM »
Depending on report type, those are average listener number and playcount. The column headers will be added, as seeing only the number is pretty odd. We'll also add filters (do not include certain file types in the report) and custom fields.
Yes, why not - we'll add a "Test" button that will send a test notification, just to see how it works.
You can manually zip it when it's required. I'll see if we can add an option to download it in a zip format.
  • Administrator
« Reply #156 on: February 25, 2019, 04:13:50 AM »
The number must be the same in the two places: the element and the parameter (&wid=) passed to the JavaScript in the <script> section.
Radio Radio
« Reply #157 on: February 27, 2019, 07:12:28 AM »
    My reports (CSV-LIST) are still giving me a time out if I try to export/download "last Month" Everything longer than 8 days is a timeout.
    Radio Radio
    « Reply #158 on: February 27, 2019, 07:17:27 AM »
    WKOM Answer: I didnt mean to be a "smart ass and give you guys more work, but if you want to use the email alert to be "realtime" and someone want to follow up directly, you NEED to have a email to text alert possibility. We can set that up with our own mobile phone provider or software, but when you install this, you definitely want to test it. I'm not leaving my phone on ringing when I sleep for every email what comes in, however, when our terrestrial stations are "offline" I need to know asap. As I said before; We use the cloud version for our entire live stream on FM terrestrial stations. And it works perfect!!  Therefore,... and again Many thnx!
    Radio Radio
    « Reply #159 on: February 27, 2019, 07:18:32 AM »
    actucast
      • Actucast
    « Reply #160 on: February 28, 2019, 05:44:34 AM »
    Could you add to the cheduler the ability to add the end time of an event instead of the number of repetitions?
    Thank you for this great job, and it is accessible with a screen reader! That's great!!!!! :)
    • Administrator
    « Reply #161 on: March 01, 2019, 04:36:06 AM »
    We'll check it again, currently timeout is set to two minutes, this should be enough to create any report. Perhaps there is a bug.
    Actually I answered seriously, the Test button will be added to test how email notifications work (it will send a test notification). RadioBOSS Cloud will currently not send text (sms) notificaions as they cost money and this requires building a new infrastructure to allow purchasing SMS credits and this is not what we want to spend dev resources on right now.
    Repeats allow to repeat an event. We may add expiration feature, similar to the one regular RadioBOSS has: https://manual.djsoft.net/radioboss/en/scheduler_options.htm
    You're welcome!
    Radio Radio
    « Reply #162 on: March 01, 2019, 06:17:34 AM »
    DJSOFT Answer: Actually I answered seriously, the Test button will be added to test how email notifications work (it will send a test notification). RadioBOSS Cloud will currently not send text (sms) notifications as they cost money and this requires building a new infrastructure to allow purchasing SMS credits and this is not what we want to spend dev resources on right now.
    For everyone who is interested to receive text alerts after RadioBoss Cloud send a error email alert:
    Most mobile phone providers offer the possibility to send email to text. When RadioBoss send an email with error alert, you can automatically forward this email to your cell phone nr.
    For example in gmail: Create a filter, with a forward address to your cell phone "standard email to text address)
    For examples see link:
    https://www.cnet.com/how-to/auto-forward-important-email-to-your-phone-as-a-text-message/
    https://www.howtogeek.com/210956/how-to-configure-automatic-text-message-alerts-for-important-emails/
    DJSoft: Thank you for all the hard work! In this way you guys don't have to create an "alert to text" environment. It is already available! Thank you for the test button!! Awesome!!
    actucast
      • Actucast
    « Reply #163 on: March 01, 2019, 06:52:59 AM »
    I have suggestions for improving accessibility with a screen reader.
    Do you want me to write them here or in an email so as not to annoy the forum?
    • Administrator
    « Reply #164 on: March 02, 2019, 04:17:24 AM »
    Please create a separate topic on this forum, this would be the most convenient to manage.
    Thank you. The test button is scheduled for the next release (0.6.1).
