• English
  • Deutsch
  • Español
  • Русский
RadioBOSS box
Author Topic: RadioBOSS Cloud [beta]  (Read 108256 times)
Callum
Re: RadioBOSS Cloud [beta]
« Reply #210 on: April 08, 2019, 02:02:54 PM »
I see, thanks for the clarification. :)
actucast
    • Actucast
« Reply #211 on: April 09, 2019, 03:24:50 AM »
I ask him to start reading the playlist in order, but it starts with part 08, then part01, 02, 03, 04 ....
If it was playing previously, then it will continue from the position it left off. Even if it was in another playlist. When you add a new item, it will still check what the position for that folder was. It could be that when you have it played previously, it played the 07 file, and now it plays 08 as it's the next one in the queue.
Ok. Is there a way for playback to always start from the beginning of the folder?
« Last Edit: April 09, 2019, 10:04:17 AM by djsoft »
  • Administrator
    • http://www.djsoft.net
« Reply #212 on: April 09, 2019, 10:07:07 AM »
It's not possible, as it will require a way to specify when to continue, and when to start over. And, also, in this case, it will be missing the last file, if you start over earlier, before it played the last track from the folder.
If you know how many files there are, and it's constant, you should schedule it to play so that it plays all files from the folder, to make sure that it starts from the first file when needed.
actucast
    • Actucast
« Reply #213 on: April 09, 2019, 01:55:03 PM »
I'm trying to add a tracklist to a playlist, but I have the error "No item selected."
I'm using a screen reader, I think I can not select folders ...
Steffen Schultz
    • Powerradio4u
« Reply #214 on: April 09, 2019, 02:21:33 PM »
Try to hit enter on the desired folder, this will select it and you can press the OK button.
  • Administrator
« Reply #215 on: April 09, 2019, 02:27:03 PM »
RadioBOSS Cloud 0.6.4 beta
  • Minor changed in UI design
  • Prelisten and download music in Media
  • Performance improvements
  • Minor bugs fixed
jordelquino
« Reply #216 on: April 09, 2019, 11:26:25 PM »
Please fix the system, I can't schedule my playlists since the last update   :(
Steffen Schultz
    • Powerradio4u
« Reply #217 on: April 10, 2019, 03:27:22 AM »
Yes, I can confirm this. If I select a playlist and try to add a tracklist to it, the message "No media selected" is being displayed. Adding files manually using the "To playlist" button however works.
actucast
    • Actucast
« Reply #218 on: April 10, 2019, 09:48:07 AM »
Don’t work ;)
  • Administrator
« Reply #219 on: April 11, 2019, 03:10:54 AM »
Don’t work
Sorry, it appears that the last update broken this - will be fixed shortly (within an hour).
ubmchicago
« Reply #220 on: April 11, 2019, 08:17:36 AM »
OK. Finally have the picture of the function we need to come to the cloud...
In the picture listed, this is the tickbox in the Scehdule Event module that would allow you to desginate the hours/minutes you want a particular event to be executed. Wanted to know if this would be coming to future versions of the RadioBoss Cloud to better schedule events...
actucast
    • Actucast
« Reply #221 on: April 11, 2019, 01:23:01 PM »
In the player, could you add an option to adjust the volume?
  • Administrator
« Reply #222 on: April 11, 2019, 02:34:35 PM »
Yes, we have this feature planned and it will be available within 1-2 months (it depends on various things).
  • Administrator
« Reply #223 on: April 11, 2019, 02:35:33 PM »
It is in the Settings, Audio - a slider called "Playback Level".
gaetanlabrecque
« Reply #224 on: April 12, 2019, 04:25:12 AM »
Hello
Since a couple of days I keep receiving emails saying
Notification details: TrackList warning: unable to find appropriate track, please check repeat protection rules
I have not changed anything for many weeks.  What is wrong?
Greetings
