• English
  • Deutsch
  • Español
  • Русский
RadioBOSS box
Author Topic: RadioBOSS Cloud [beta]  (Read 108263 times)
  • Administrator
    • http://www.djsoft.net
Re: RadioBOSS Cloud [beta]
« Reply #225 on: April 12, 2019, 05:42:26 AM »
Notification details: TrackList warning: unable to find appropriate track, please check repeat protection rules
This means your repeat protection rules are too strict, and it's unable to find a track that fits the criteria. You should adjust the repeat protection settings.
  • Administrator
« Reply #226 on: April 18, 2019, 12:21:37 PM »
RadioBOSS Cloud 0.6.5.3 beta
What's new
  • Speed optimizations to improve control panel performance
  • Administrator
« Reply #227 on: April 19, 2019, 03:35:22 AM »
RadioBOSS Cloud 0.6.6 beta
Changes
  • Quick start hint did not hide for some accounts
  • Library update button moved from Settings to Media
  • Minor bugs fixed
djsp1
« Reply #228 on: May 08, 2019, 10:10:49 PM »
Where is everyone?
Radio Radio
« Reply #229 on: May 12, 2019, 04:03:17 AM »
RadioBOSS Cloud is working like a well oiled machine... :) :) :)
No reason to be on the forum, other than waiting for more great updates!
Thank you, for a fabulous cloud based scheduling software!
  • Administrator
« Reply #230 on: May 14, 2019, 08:51:04 AM »
Thank you! An update is currently under development, but as it now has lots of active users - we spend much more time on testing now, to make sure an update does not break anything.
SertanejaPop
    • Sertaneja Pop
« Reply #231 on: May 15, 2019, 02:31:02 PM »
Is it possible to keep ftp synchronized with the computer?
  • Administrator
« Reply #232 on: May 16, 2019, 01:58:42 AM »
Yes, but you'll need a software to do it - there's plenty software to perform FTP sync.
Radio Radio
« Reply #233 on: May 16, 2019, 03:41:43 AM »
ubmchicago
Re: RadioBOSS Cloud [beta] - clear playlist upon new event
« Reply #234 on: May 30, 2019, 05:08:08 PM »
Hey. Here's an idea for the next update:
As you create an event, have an option to have the playlist clear to allow the event run uninterrupted.
Just a thought.
  • Administrator
« Reply #235 on: May 31, 2019, 12:51:31 AM »
You can use the "Replace playlist" option - it will clear the current playlist window contents and insert the event. So only event will be in the playlist.
  • Administrator
« Reply #236 on: May 31, 2019, 05:12:13 AM »
RadioBOSS Cloud 0.6.7 beta
What's new
  • File types management: now it's possible to add and delete file types
  • Added 10 band equalizer for audio processing
  • Media: collapse and expand folders
  • Scheduled events can be sorted
  • (Track List) is not included in the reports for files with no tags
  • Fixed: apostrophe was removed from file names
  • Fixed UI problems in Edge web browser
  • Error notifications are removed, only silence notifications are sent
  • Fixed FTP-related bugs
  • Minor improvements
Radio Radio
« Reply #237 on: May 31, 2019, 03:47:33 PM »
(Track List) is not included in the reports for files with no tags.
What does this mean?
If no TAG at all (NO Title, Artist, Album, Year, Start Date, Start Time, Length, AND Listeners) are found, it will not show up on export?
OR if just 1 one of the TAGS are not found, the entire song/spot or whatever is not exported?
Kinda confused..
All other upgrades are awesome specially the collapse and expand folders
THNX! Marty
actucast
    • Actucast
« Reply #238 on: May 31, 2019, 03:51:15 PM »
Hi! :)
the equalizer is not accessible with a screen reader. Could you correct that?
Could you add a button to reset it? :)
Thank ;)
wireradio
« Reply #239 on: June 01, 2019, 04:47:35 AM »
Are we going to be able to use dropbox with rb cloud so we can play shows from inside dropbox
thanks
