• English
  • Deutsch
  • Español
  • Русский
RadioBOSS box
Author Topic: RadioBOSS Cloud [beta]  (Read 56285 times)
0 Members and 2 Guests are viewing this topic.
WKOM Radio 101.7 FM
  • WKOM Radio 101.7 FM | NashVille TN
Re: RadioBOSS Cloud [beta]
« Reply #240 on: June 02, 2019, 03:36:19 AM »
Are we going to be able to use dropbox with rb cloud so we can play shows from inside dropbox
thanks
Yes, or Google Drive, incl real live syncing from google drive to Cloud like Sync FTP would be super...
But these are the Cherries on the Pie... (and you guys bake code not Pies... ;D )
     WKOM Radio 101.7 FM  |  --> Over 2 years Terrestrial Radio Running on RadioBoss Cloud without issues! <--
  • Administrator
    • http://www.djsoft.net
« Reply #241 on: June 02, 2019, 05:13:37 AM »
(Track List) is not included in the reports for files with no tags.
What does this mean?
If no TAG at all (NO Title, Artist, Album, Year, Start Date, Start Time, Length, AND Listeners) are found, it will not show up on export?
OR if just 1 one of the TAGS are not found, the entire song/spot or whatever is not exported?
Previously, if a track had no tag information, and was launched with Track List, the track appeared in the reports as "(Track List) filename". Now it will try tom parse the file name (to separate artist and title), and the (Track List) part is removed. Tracks with tag information are not affected.
the equalizer is not accessible with a screen reader. Could you correct that?
Could you add a button to reset it?
Yes, It think this will be possible.
We have this planned for the future, but currently I can't promise anything.
wireradio
« Reply #242 on: June 07, 2019, 07:25:28 AM »
hi
When we post to twitter on cloud is there a away of changing the colour of the artist and song or making it in bold so it stands out more
cheers
RBUser2010
« Reply #243 on: June 09, 2019, 03:23:49 PM »
Hello - Is there a way we can use the “Do not send title to server” option in file types when using an FTP/URL link? Right now it only allows you to select a local file, but any FTP/URL link is being broadcast to the stream and we’d like the option to designate a location and select anything from that URL to not send the title  to the server.
WKOM Radio 101.7 FM
« Reply #244 on: June 10, 2019, 11:56:18 AM »
I also have a FTP question:
We are trying to set up a "auto Sync FTP" but receive every time the same error:
ftp sync upload "550" error
We tried several programs for this (Cyberduck, Freefilesync, MAC OS Finder, FTP synchronizer) but every time get the same error.
All settings are as discussed on RadioBoss Cloud and settings page in Cloud.
The software companies say it's a autorisation issue on RAdioBoss Cloud side...
Is this correct?
Is there a way to work around this?
Do you know any software what DOES works?
Thnx MArty
WKOM Radio 101.7 FM
« Reply #245 on: June 10, 2019, 12:33:00 PM »
Also; Are there any plans to have a  RadioLogger available in the future as a part of RadioBoss Cloud?
If I had to purchase extra disk space and knew that the last 52(? or less) weeks are available, I would do it in a heartbeat.
I know all terrestrial radio co's in the US need to have some...
John Drake
« Reply #246 on: June 10, 2019, 03:09:41 PM »
Question: Can RadioBoss Cloud work with music scheduling software like MusicMaster or Powergold?
Thanks for a great product guys!
wireradio
« Reply #247 on: June 13, 2019, 08:25:12 AM »
i Tell you what would be good to do
Re order the Scheduler so you can put it in a easy order
cheers
  • Administrator
« Reply #248 on: June 14, 2019, 05:48:45 AM »
AFAIK, Twitter only allows plain text to be posted. No formatting is allowed.
Currently this is not possible - this will be added in one of the next updates.
Have you tried a regular FTP client like FileZilla, does it work for you? Did you use plain FTP or FTPS protocol?
Yes, it is planned. Not RadioLogger but it will record what's being broadcast and allow downloading it.
Currently no, as it does not allow uploading external playlists - there are technical and security reasons for such a limitation, as well as complicated setup, as to make it work you will have to somehow match the paths on your computer with paths on RB Cloud's server.
Do you mean moving scheduled events in the list, or changing the way the events table looks?
wireradio
« Reply #249 on: June 14, 2019, 09:24:56 AM »
hi
yes just moving the events so things added at a later stage you can move by other things like it
cheers
WKOM Radio 101.7 FM
« Reply #250 on: June 14, 2019, 08:52:21 PM »
Is this correct?
Thnx MArty
REGULAR FTP works great.
I'm trying to set up (like other people here) auto sync from folder on computer -> auto sync -> to Radioboss Cloud.
It gives us a 550 error, what turns out a server authentication issue.
Other solution would be "Folder Level" access by other people.
We have employees which are making commercials/spots, music, news etc. Now I have to give them ALL the general authorisation login password etc, with the possibility that they change or accidently change something in the playlist with issues in regards of our UPTIME on the terrestrial station
Auto sync FTP would cover that problem through automatically updating and syncing the folders from PC to radioBoss Cloud./ We can give locally rights to certain Folders, so NOT everyone has access to RadioBoss Cloud...
Please help...
« Last Edit: June 14, 2019, 08:58:00 PM by WKOM »
  • Administrator
« Reply #251 on: June 15, 2019, 07:12:13 AM »
In this case I'm not sure how it's possible. Auto sync is still a regular FTP and it works exactly the same, except that it automated uploading/downloading, but auth and everything else is no different. I suggest to limiting the number of concurrent connections (to 2-3), this is the only thing that I see to possibly cause problems.
We plan on adding such a feature - additional logins with limited access to features. But this is a pretty complex thing so will be available within 6-9 months.
  • Administrator
« Reply #252 on: June 17, 2019, 02:02:59 PM »
RadioBOSS Cloud 0.6.8 beta
What's new
  • Added "Expand all folders" option to show all folders as expanded in media
  • Fixed: general crossfade setings were not saved
  • Fixed rendering bug in scheduled events table
  • Added "Reset" button for the equalizer
  • Fixed expand arrow display in certain web browsers
jordelquino
« Reply #253 on: July 04, 2019, 04:35:02 PM »
Hello!
Can you develop a function to kick live source (stop live broadcast from the panel)? And a function to record live shows? Would be great.
Mars_bcn
« Reply #254 on: July 05, 2019, 09:26:30 AM »
Hi,
The “Current Listeners” section doesn’t show all connections. Sometimes I see I have some listeners, but this section just shows one IP. Also, when I listen from my mobile device, my IP is not shown.
Is there a “work in progress” in this section? In addition to show all connections it would be great if it could show more info: City, Referer, OS...
Thank you,
Marc
