• English
  • Deutsch
  • Español
  • Русский
RadioBOSS box
Author Topic: RadioBOSS Cloud [beta]  (Read 93022 times)
0 Members and 3 Guests are viewing this topic.
ubmchicago
Re: RadioBOSS Cloud [beta]
« Reply #345 on: January 19, 2020, 11:26:17 PM »
The change in the upload file dialog is a lot better. Thanks!
  • Administrator
    • http://www.djsoft.net
« Reply #346 on: January 20, 2020, 04:07:22 AM »
I'm glad you find the change useful, thank you :)
Steffen Schultz
    • Powerradio4u
« Reply #347 on: January 20, 2020, 09:40:34 AM »
Thank you for the new API. Could you add user account information to the output if applicable? Users with live streaming permissions then could be displayed on the radio's home page if they are currently broadcasting.
Steffen
  • Administrator
« Reply #348 on: January 22, 2020, 02:39:46 AM »
For this to work, you'll also need to know the name of DJ who is currently connected. It's not really logged at the present, it only ititially checks if a dj is allowed to stream and then it's not saved anywhere. I'll schedule this for the future updates.
cpereyra
« Reply #349 on: January 23, 2020, 11:04:12 AM »
Hi, here's a new user. I ask about which external HTML player worked well with the RadioBOSS Cloud, especially showing the cover art of each song broadcast. I did a test with the famous HTML5 Radio Player, but the small version does not fit the design of our website.
Greetings and thank!!!
  • Administrator
« Reply #350 on: January 24, 2020, 08:19:42 AM »
Any player will play the stream supplied by RadioBOSS Cloud. For artwork and any other additional information, please consider using the widgets provided in the Integration section.
SertanejaPop
    • Sertaneja Pop
« Reply #351 on: January 25, 2020, 12:16:02 PM »
I created this schedule to run on Fridays and Saturdays, with just two repetitions. But it continued to repeat every 150 minutes. If you can check the logs you will see.
SertanejaPop
    • Sertaneja Pop
« Reply #352 on: January 25, 2020, 12:18:22 PM »
I created this schedule to run on Fridays and Saturdays...
Then I modified and created two schedules to prevent it from repeating every 150 minutes.
Radio Radio
« Reply #353 on: January 26, 2020, 04:50:54 PM »
I think I have an issue with the scheduling.
When My scheduler says that the item should run mo-sat but not on sunday, it kept repeating the message ALSO on Sunday. It has not done this before. See attached image for settings....
Is this a bug or am I doing something wrong?
Radio Radio
« Reply #354 on: January 26, 2020, 05:09:03 PM »
I have the same issue and created also 2 scheduling items. The problem is: We have so many schedulers running that it becomes hard to keep the overview of "What is What"
Marty
Radio Radio
« Reply #355 on: January 26, 2020, 05:13:23 PM »
Any News about the possibility to upload Files straight from Google Drive? I mentioned this a year ago or so and you guys said that it would be a future development for Google Drive & Dropbox. It would be great if there would be a syncing possibility with Google Drive....
But I know; It's asking to have the Porsche drive like a F1 Car..... (But it would be great!)
For the Rest: RadioBoss Cloud is the Best!
Talk to you guys later, thnx!
  • Administrator
« Reply #356 on: January 27, 2020, 09:04:33 AM »
The logs (for 2020-01-25) indicate the following:
"7:00:04 PM";scheduler;"Starting event ""Rafael Callegaro, Sorriso Lindo""";
"9:30:04 PM";scheduler;"Starting event ""Rafael Callegaro, Sorriso Lindo""";
Only two entries for this event to start - appears to be correct.
However, the track thisd event starts was started much many times (like 15 times):
"12:35:17 AM";;"Rafael Callegaro, Sorriso Lindo - Se O Amor Virar Saudade"
"2:03:59 AM";;"Rafael Callegaro, Sorriso Lindo - Se O Amor Virar Saudade"
"3:34:05 AM";;"Rafael Callegaro, Sorriso Lindo - Se O Amor Virar Saudade"
... and so on.
It looks like the track was added to the playlist by another event, I think it's an event named "Lançamentos (Sexta & Sábado)": this event starts every 28 minutes and selects tracks from the folder where "Rafael Callegaro, Sorriso Lindo - Se O Amor Virar Saudade" is located, so it can also select this track and add it to the playlist.
Radio Radio
« Reply #357 on: January 27, 2020, 09:10:27 AM »
... and so on.
I had the same issue. Running a scheduler for the past 2 years or so, and suddenly the scheduler did not adhere to the rules. This is still going on (as per 2 am last night)
Please check....
Radio Radio
« Reply #358 on: January 27, 2020, 09:12:24 AM »
UPDATE: The scheduler was set NOT to run on sundays. But it DID run on Sundays.
  • Administrator
« Reply #359 on: January 27, 2020, 09:25:16 AM »
This event is configured correctly, but there is another event named "1STAT Wellness Sundays" that starts the same item on Sunday, it could be the cause.
At the time of writing this post, the logs indicate the "STAT Wellness Shorts" event indeed started on Sunday every 26 minutes, but it's hard to tell what was wrong - there's no event with such name now, and the one named "kSTAT Wellness Shorts" has different configuration that you posted on your screenshot and I suppose it was also configured differently on Sunday.
