• English
  • Deutsch
  • Español
  • Русский
RadioBOSS box
Author Topic: RadioBOSS Cloud [beta]  (Read 108268 times)
0 Members and 2 Guests are viewing this topic.
  • Administrator
    • http://www.djsoft.net
Re: RadioBOSS Cloud [beta]
« Reply #405 on: March 04, 2020, 06:34:28 AM »
I find it almost impossible for 90% of my audience to use VPN.
You're right - please check stats again, it should now show the correct data. The initial stats feature release had a bug.
Also, another smaller issue: When downloading reports, (which we have to do month by month because it only allows max of 60 days, but thats ok) it would be great if you can select date range "from - To" in the same month. (because of the 60 days issue.
It only limits time span for a single report - not how much back can you go. You can have monthly report for any month up to 1 year back.
It would be great if there was a tap in the admin with just a giant clock with time + seconds till end of song (or file) and how many seconds next song or file is etc. Something what a DJ or Host can look at to take over live shows from automation etc. We use a large screen on roughly 14 feet away (3 meters) and never can see the next file/song/time/how many seconds minutes left etc. - I know this is a luxury, but it would DEF. a big help in making accurate tight radio.
Giant countdown seems like a situation-specific feature, so I'm not sure if many would benefit from it, I'm sorry.
Question: Our radio stations are based in central US. My server is in Europe (paris?) We have a 10-12 second slack time. Would a server based in the US work faster with less slack? Would it be possible to move everything over? Please advice!
This happens because of buffering, not because of server location. Without the buffer, your stream playback will be unstable, especially on slow connections. The buffer size is controlled in Settings->Advanced but I strongly recommend leaving it at the default value unless you know what you're doing and why (do you really need real-time radio, and does 10 second latency make any difference?).
Transmission dropping frequently and this message appears at the top of the panel, see the print. This happens in others as players well.
How often does it happen?
SertanejaPop
    • Sertaneja Pop
« Reply #406 on: March 04, 2020, 07:58:15 AM »
This was happening yesterday with a frequency of 4 seconds, I suspected it was the Chrome browser because of "https" but besides not working on other browsers like edge and firefox I was using the "https" flow.
Radio Radio
« Reply #407 on: March 04, 2020, 01:40:54 PM »
Quote from: Radio Radio on March 02, 2020, 12:02:45 PM
I personally believe EVERY DJ/HOST want a countdown Timer....
If you Live Stream you cant work without it.
Richard Foster
« Reply #408 on: March 05, 2020, 03:14:42 AM »
Is there any audio processing in radio boss cloud? It sounds good.. better than any other cloud automation systems we have tried ..
  • Administrator
« Reply #409 on: March 05, 2020, 03:35:43 AM »
Currently you should use the https links everywhere - please note that it's not enough to simply change http to https, as ports are different. Please get the links from the Infomration tab.
About interruptions, there were minor updates on March, 3 - so short interruptions were possible.
  • Administrator
« Reply #410 on: March 05, 2020, 03:38:27 AM »
A countdown timer, yes, but a huge one? We'll consider adding it in one of the future updates, or maybe add it as an API command.
Currently there's only equalizer (turned off by default) and volume leveling based on ReplayGain. Otherwise it comes as is.
SertanejaPop
    • Sertaneja Pop
« Reply #411 on: March 14, 2020, 11:23:12 AM »
This has been happening frequently, my listeners fall. I do not use additional encoders. I restarted the server and player so I could get back to normal.
« Last Edit: March 14, 2020, 11:25:07 AM by SertanejaPop »
  • Administrator
« Reply #412 on: March 16, 2020, 02:59:18 AM »
How often does it happen, and do you still experience this problem? Also, when it happens it should be enough to restart the server only, as it appears to be some server related issue.
SertanejaPop
    • Sertaneja Pop
« Reply #413 on: March 16, 2020, 11:12:10 AM »
That's what I did, restarted and resolved, but I often say about three days. If I am not aware it is a problem because the ear drops, audio stops, then I have to be aware. It's not a problem?
  • Administrator
« Reply #414 on: March 18, 2020, 04:01:26 AM »
We don't see this happening with other accounts. Please specify your account user name to check.
SertanejaPop
    • Sertaneja Pop
« Reply #415 on: March 19, 2020, 06:00:33 AM »
Wheslley_Andrade
  • Administrator
« Reply #416 on: March 20, 2020, 02:43:41 AM »
According to the logs for the past 30 days, it happened twice, it also doesn't appear to happen with other accounts. Please let me know if you see this behavior again, we'll think of some solution.
SertanejaPop
    • Sertaneja Pop
« Reply #417 on: March 20, 2020, 10:16:12 AM »
Actually, this happened twice, but I have noticed a general delay when accessing the panel, connection with streaming, I realized that other radios have a faster connection than mine.
  • Administrator
« Reply #418 on: March 23, 2020, 04:28:38 AM »
They are all served from the same connection, so I doubt it can be faster or slower. In your case, it appears to be some sort of Icecast bug that caused this behaviour. I think we should wait and see what happens next. At this point, I don't see a way to diagnose it.
SertanejaPop
    • Sertaneja Pop
« Reply #419 on: March 25, 2020, 10:46:07 AM »
It happened again, today 03/25 check the logs, I had to restart the server, but until I did that the radio stopped, this instability compromises the credibility of the radio, I always praised the stability of the Radioboss Cloud, unfortunately I cannot say the same in time.
