• English
  • Deutsch
  • Español
  • Русский
RadioBOSS box
Author Topic: RadioBOSS Cloud [beta]  (Read 108174 times)
0 Members and 3 Guests are viewing this topic.
  • Administrator
    • http://www.djsoft.net
Re: RadioBOSS Cloud [beta]
« Reply #480 on: May 20, 2020, 04:18:13 AM »
Question: why does an event, after you give it a date to disable, doesn't want to re-enable when you do so?
The option as its name implies, only disables an event - it does not re-enable it. This is by design. If you need an event to run during certain period of time, you can consider using the "Repeat every" feature and limit the number of repeats.
I shall be very pleased if i could generate playlist with genres and bpm info.
Can you please provide more information on what it should do?
actucast
    • Actucast
« Reply #481 on: May 23, 2020, 10:06:45 AM »
Hello !
Are you planning to add a duplicate song tag finder? Many of us are adding music and we would like to have a function that searches for duplicate titles. I think it is a very important function I hope it will be added because I do not know how to do ...
  • Administrator
« Reply #482 on: May 24, 2020, 04:11:23 AM »
Curently we do not plan on adding such a feature. We'll add file search option soon - this may help you find duplicate songs.
SertanejaPop
    • Sertaneja Pop
« Reply #483 on: June 10, 2020, 10:26:33 AM »
It would be nice to be able to modify the appearance of the audio being played, font color and background, as currently it is only in bold and sometimes it is difficult to locate among the others.
  • Administrator
« Reply #484 on: June 13, 2020, 02:54:21 AM »
Thank you for the suggestion, the option will be added in one of the updates.
Steffen Schultz
    • Powerradio4u
« Reply #485 on: June 23, 2020, 03:44:05 PM »
The TLS certificate for the FTP service on c2.radioboss.fm has expired, can you please renew it?
« Last Edit: June 23, 2020, 04:02:52 PM by Steffen Schultz »
  • Administrator
« Reply #486 on: June 24, 2020, 10:00:46 AM »
Thank you for informing about the issue, it was renewed - please check.
« Last Edit: June 24, 2020, 10:04:23 AM by djsoft »
  • Administrator
« Reply #487 on: June 24, 2020, 10:02:45 AM »
RadioBOSS Cloud 0.8.6 beta
Changes:
  • Added Greek encoding for ANSI file tags
  • Improved FTP download speed
  • Fixed errors when working with file names containing runs of dots
  • Icecast KH server updated to version 14
  • Minor performance improvements
Steffen Schultz
    • Powerradio4u
« Reply #488 on: June 24, 2020, 10:21:21 AM »
Thanks, everything working fine again.
  • Administrator
« Reply #489 on: June 27, 2020, 12:35:03 PM »
RadioBOSS Cloud 0.8.6.2 beta
What's new
  • Fixed: external live stream sometimes did not mute overlay events
  • Fixed: scheduled events queue bug in the playlist (in rare cases tracks could be skipped)
  • Fixed: file type playback level sometimes did not work
  • Improved fading when transitioning to and from live streaming
  • Improved crossfading when mixing music tracks
  • Fixed minor issues with playback
  • Performance improvements
  • Fixed: reports sometimes were not created and an error message was shown
SertanejaPop
    • Sertaneja Pop
« Reply #490 on: June 28, 2020, 03:06:42 PM »
I have seen Radioboss Cloud very slow lately, it presents an error constantly with this message "Unable to load page: 0 (error)", I also noticed that after the last two updates the crossfade does not obey the given configuration, I put the mix in 4.0 seconds and it doesn't mix in that time, the audio is played until the end.
  • Administrator
« Reply #491 on: July 01, 2020, 06:50:20 AM »
Thank you for letting us know, we'll check if there's a problem with it.
Matt Barton
« Reply #492 on: July 03, 2020, 04:27:23 AM »
Up until a few days ago (before a software update?) my station was playing fine - playing the playlist tracks randomly with IDs being inserted every 20 minutes according to the scheduler.
The IDs then stopped playing (error code 2 in the log - unable to open the file/invalid server address). I deleted the schedule and reset the events, and I no longer get error code 2. However the scheduled IDs do not play. They get added to the playlist but do not play out on schedule. I have tried different insert methods - queue after playing track, replace scheduled track etc.
How can I get an ID (randomly chosen from my IDs folder) to play out at scheduled times, when the playlist is playing randomly? It worked before but does not work now. Thank you!
Chris Deacon
« Reply #493 on: July 03, 2020, 06:25:31 AM »
Congratulations on a most elegant application!   I have an urgent application for your consideration...
Because of covid-19, we are trying to come up with a solution to enable its use by remote DJs equipped with RB and with autodj pointed at an icecast server at our studio rather than permanently locked to your server. When the DJ's log in as live feeds, the autodj would be temporarily taken over by the live stream.
Can this be added as an option so we can stream to our own custom server?  At the studio, the incoming stream needs to be combined somehow with studio audio output and re-encoded using RadioCaster or RadioBoss pointed at your server.   What would be the best way to do this?
RadioCaster could be pointed at the mountpoints for RBC and RBC use its second encoder feed to send to the studio but the RBC autodj feed would need to be disconnected while this happens.
I suppose something might also be possible using the relay feed in RadioBoss.   What do you think?
I'm sure this would be of interest to the many stations trying to assist home broadcasters at this time.
ArtSound FM
Canberra
  • Administrator
« Reply #494 on: July 05, 2020, 04:00:41 AM »
This indeed was caused by a recent software update, and we're sorry for it. Before we rolled out an upodate we've been testing it here for over a month, but still some bugs made their way to the release :)
The problem you describe was fixed in the most recent minor update and everything should be working fine now.
It is possible and there are two options:
1. Stream live - when you connect to the server it will switch to the live stream, please see this page for the details: https://www.radioboss.fm/radioboss-cloud/live-broadcast/
You can use your login details or create DJ accounts so that they havge their own passwords with limited rights.
2. Make AutoDJ play external stream. E.g. schedule it to start a network stream and specify the address, it will play it at set times.
