• English
  • Deutsch
  • Español
  • Русский
RadioBOSS box
Author Topic: RadioBOSS Cloud [beta]  (Read 108255 times)
Mike
Re: RadioBOSS Cloud [beta]
« Reply #510 on: July 21, 2020, 04:55:46 PM »
I realize that crossfade settings are not working like they should.
Yes, there was a minor bug with crossfade settings processing, we've fixed it but the update is not yet installed on all the servers. Please check how this works now, the problem with crossfades should be solved for your accounts.
Hello! The crossfade settings still not working properly.  :(
  • Administrator
    • http://www.djsoft.net
« Reply #511 on: July 22, 2020, 03:29:31 AM »
Any idea why https streams seem to take a lot longer to load than the http versions?
How much longer is it? From the technical point of view, it will take longer as SSL connection needs more work to be done (SSL handshake, certificate validation, encrypting etc), but it shouldn't be a lot longer than plain HTTP connection.
Also, is it possible to use our own ssl with your servers?
No, we only allow using our own certificate. What is the purpose of using your own certificate? If you use the links we provide (with "radioboss.fm" domain), you won't be able to obtain the certificate as it requires domain control validation.
  • Administrator
« Reply #512 on: July 22, 2020, 03:30:22 AM »
Apparently it is working perfectly, it was fast and there was no error.
Thank you, good to know.
Can you please specify what is not working with the crossfades?
Mike
« Reply #513 on: July 22, 2020, 09:49:45 AM »
[/quote]
Example: When a song is ending, it mixes with a Jingle/Station ID... then next song only begins after the end of the Jingle/Station ID without mixing...
This was working ok, but it's not anymore.
  • Administrator
« Reply #514 on: July 26, 2020, 04:05:14 AM »
Please check the crossfade settings for jingle and station IDs, it appears that the Mix is set to "0" which means no overlap.
Mike
« Reply #515 on: July 26, 2020, 04:28:22 PM »
You said there was a bug... I've tried to change the settings but the problem remains... Maybe it will be fixed in the next update (?)
  • Administrator
« Reply #516 on: July 27, 2020, 06:13:28 AM »
It was fixed, and should be working as intended now. You can increase track overlap (I see that you currently use 1.5 sec) and also enable fade in and fade out for smoother transition.
tking
« Reply #517 on: July 28, 2020, 09:01:14 AM »
Sorry I should have said that this difference specifically appears on chrome/pc. For example in Firefox both HTTP and HTTPS streams start instantly (no discernible delay at all).
The main purpose is we supply many users behind corporate firewalls. It would make it easier for us to provide whitelisting details with one domain, we also have some legacy streaming servers hosted elsewhere.. Technically it should be possible?
  • Administrator
« Reply #518 on: July 30, 2020, 02:55:15 AM »
The difference can be due to how the browsers check certificates. We can't control it from within RadioBOSS Cloud.
This too specific and will require changes to how we configure the server, also additional security checks for user supplied certificates. I'm sorry but I don't think we'll be supporting this, at least for now.
RadioKube
« Reply #519 on: July 31, 2020, 04:34:14 PM »
Hi, is there any timeline to introduce VoiceTracking?
  • Administrator
« Reply #520 on: August 05, 2020, 06:17:27 AM »
This is planned in general but it's not yet assigned for a concrete period of time, I'm sorry, I can't tell you when it's going to be added.
Zach Moonshine
  • Underground metal promoter and owner of https://t.co/MG8ZcnCFEz
« Reply #521 on: August 06, 2020, 06:02:07 PM »
Love the sound quality of the new server and so far everything i am seeing looks and works great except one major thing. When in auto dj mode the playlist widgets (now playing, album art etc.) all display correctly but when i switch over to live dj, the album art continues showing what is playing in auto dj and the now playing shows what i am playing live. has anyone else encountered this issue? Do i have something set up wrong? I tried it on a several broadcasting platforms and several of my other djs all encountered the same issue?
SertanejaPop
    • Sertaneja Pop
« Reply #522 on: August 06, 2020, 06:05:24 PM »
Hello, I have a super stable connection, but Radioboss Cloud is slow and has several errors, I did a test using a VPN and so Radioboss works perfectly, why does this happen?
  • Administrator
« Reply #523 on: August 09, 2020, 10:05:45 AM »
Yes, this is a problem that is reported sometimes. We'll fix it in one of the next updates. I'm sorry for the inconvenience.
If it works fine with VPN then it means that a direct connection from you to RadioBOSS Cloud server is not good (e.g there is an intermediate node that slows down things). When you use a VPN the path from you to RB Cloud is different and faster. We can't do anything about it as the problem is not on our side - all our servers have plenty of bandwidth available.
  • Administrator
« Reply #524 on: August 11, 2020, 04:48:30 AM »
RadioBOSS Cloud 0.8.8 beta
Changes:
  • Fixed: "trigger mix at" crossfade option was incorrectly processed sometimes
  • Fixed: cover art was incorrect when streaming live and after disconnecting live stream
  • Added guide about using DJ accounts
  • Other bug fixes and improvements
