• English
  • Deutsch
  • Español
  • Русский
RadioBOSS box
Author Topic: What Exactly Do I Need?  (Read 3066 times)
DjDominic
« on: September 21, 2019, 06:28:28 PM »
If I want to stream to either Icecast or Shoutcast what do I need? I have RadioBoss and RadioCaster. I think I also need RadioCloud and Centovacast. Do I need RadioCloud if I want to stream live 24/7? I do not want to use the AutoDJ feature. I would be streaming live 24/7 from RadioBoss.
  • Administrator
    • http://www.djsoft.net
Re: What Exactly Do I Need?
« Reply #1 on: September 22, 2019, 04:24:29 AM »
You need either of those. But as CentovaCast is not being actively developed, we do not recommend using it. I suggest using RadioBOSS Cloud. It's also easier to configure to use with RadioBOSS. Even if you stream 24/7, you can use AutoDJ as backup solution just in case.
DjDominic
« Reply #2 on: September 22, 2019, 12:55:44 PM »
Thank you for the information. I am going to give it a try with RadioCloud.
