Hotkey combination for archive recording
Are you able to add a hotkey feature to pause and unpause recording?
This would enable voice only airchecks triggered by an external mic on control.  A USB interface could trigger the keyboard hotkeys....shouldn't be too difficult given that record function is already in place.
When you start recording, it first shows a window that asks for file name and other options, and currently there's no way to pause/unpause it. You can probably use the API https://manual.djsoft.net/radioboss/en/remote_controlapi.htm to call the streamatrchive command however this will be sort of complicated. With hot key, it can simply start the recording using the last parameters, but I'm not sure if it fits the purpose.
