RadioBOSS 6.0 [beta]
Exactly, it produces a constant loop of choppy audio
Do you use a large network buffer size? A quick test does not confirm the problem here, when the stream stops, it moves on to the next track within several seconds.
RadioBOSS 6.0.0.7 beta
Changes
  • AccuWeather does not require entering API key (if you already use the key, you can remove it)
  • Added "Black" theme
  • Styles can be changed without program restart
  • Fixed cart wall font became larger sometimes
  • Fixed "getfile" command played files were not removed
  • Fixed cart wall did not stop sometimes
  • Fixed library update did not remove non-existent tracks
  • Fixed "repeat track" bug did not work properly with scheduled tracks
  • Added multiline hint for Comment field in playlist and track information
  • Fixed: event with commands was not removed from the playlist
  • Added hint for values in Track Tool for better readability
  • Fixed playlist selection color setting did not work properly sometimes
  • Total playlist duration shows days
Download: https://dl.djsoft.net/beta/radioboss_beta_6.0.0.7.exe
In 6.007 Music Library black frame?
What do you think about to bring back the info window how many entries are deleted when "Remove entries for non-existet track" ? To be shure that is everything ok with the tracks. Now I have no clue what's going on...
The problem with commands, which had been solved in version 6.0.0.5 came back in version 6.0.0.7
Cambios
  • AccuWeather no requiere ingresar la clave API (si ya usa la clave, puede eliminarla)
  • Se agregó el tema "Negro"
  • Los estilos se pueden cambiar sin reiniciar el programa
  • La fuente de la pared del carro fijo se hizo más grande a veces
  • Los archivos reproducidos con el comando "getfile" fijo no se eliminaron
  • La pared del carro fijo no se detuvo a veces
  • La actualización de la biblioteca fija no eliminó las pistas inexistentes
  • Se corrigió el error de "repetir pista" que no funcionaba correctamente con las pistas programadas
  • Se agregó una sugerencia de varias líneas para el campo de comentario en la lista de reproducción y la información de la pista
  • Corregido: el evento con comandos no se eliminó de la lista de reproducción
  • Se agregó una pista para los valores en la herramienta de seguimiento para una mejor legibilidad
  • La configuración de color de selección de lista de reproducción fija no funcionaba correctamente a veces
  • La duración total de la lista de reproducción muestra días
Descargar : https://dl.djsoft.net/beta/radioboss_beta_6.0.0.7.exe
The Program restarts when changing the styles by cutting the Streaming transmission
RadioBoss 5.9.4.0 vs 6.0.0.6
Prior to release 6, a scheduled TTS event that uses the "Overlay Playback" option would not execute until the currently playing track finished. Beginning with release 6 the event triggers immediately and plays over the currently playing track. I don't know if the release 6 method is the way you intend it to work or if this is a bug that needs to be fixed. I definitely prefer the prior to release 6 method. I use it for several situations. I'm not sure what practical use there is for the release 6 method. If you intended it to be the new way could you add an option to make it backward compatible.
It was not changed in this version. You can control this if you use the "Maximum time to wait" option for the scheduled event.
I have tried variations of the event settings (now using 6.0.0.7) and none of them change the playback. The TTS event plays as soon as the event is triggered. Could there be any other setting(s) that could affect this?
Hice un video de Youtube para eso pero está en alemán
Quizás ayude un poco.
https://www.youtube.com/watch?v=Hh-BuGuNnvY
Aquí un manuel para anuncio automático
[URL unfurl = "true"] https://manual.djsoft.net/radioboss/en/index.html?automatic_weather_announcement.htm [/ URL]
Gracias. Tu video fue muy útil. Me arroja un error al actualizar accuweather que es el que quiero usar ya que es más preciso en nuestra zona. Te muestro los errores que arroja RB al actualizar.
The buffer is 10 seconds. As encoder we use the one integrated in RadioCaster
I am using a different vinyl sound vst plugin for 24hrs now and Radioboss has not crashed and restarted yet. I do not like this different vinyl sound plugin it sounds a lot more computerized and fake compared to the other one also if you play around with the settings you can your audio to sound like the treble is at 100% to 115%.
Errors in version 6.0.0.7:
- Time and temperature announcement, is recognized but does not reproduce the temperature file.
Note: in the previous version, 6.0.0.6 the same file(playlist) worked normally.
- The "Settings" tab when clicked flashes and sometimes closes. The "i" indicator of track quantity and running file time, also blinks strangely.
Note: In a recent test, I realized that this occurs only when the list of "Scheduled Events" is enabled.
Unusual fact ocorrid: unexpectedly there was a failure in the electrical current for a long period and consequently the PC hung up. Upon returning I had the unfortunate surprise of seeing my entire system misconfigured. Radio Boss had damaged my entire system usage profile. I lost with this a good time reassembling layout, events, adding playlists, all... It would be a good thing to run a test simulating this situation to see if this could turn out to be a recurring problem.
