RadioBOSS Cloud [beta]
Repetition protection doesn't seem to work well, see the print, the first song was added to the playlist by scheduling the track list, the second song was played in less than 10 minutes.
Thank you, we'll check this. Did you hear this song actually playing by the way? There's a possible bug with the log, it sometimes includes wrong songs there.
Yes, I heard it so I decided to inform, the first song was inserted by appointment, the same artist played after this time in the playlist by tracklist.
Hi everybody!
first of all great job!
In order to put my comments in context I'll wirite a fiew lines of intro - if you don't want to get bothered jump to "nice to have"
intro:
A few weeks ago a friend came to me with the idea of a latin radio with style and without ear destroying ads... I'll have to say that my frind is a normal user and doesn't have any idea of coding broadcasting etc... After trying different services as also yor hardware boradcasting software finally I desided to use your cloud solution, which was awesomae in terms of enabling to have a serious RC1 in 3 weeks. Later on I'll explain how you could help to make it in 2 weeks. ;)
Additionally I'd like to add that it's a side proyect without any financial purpose, thus I do this in my free time...
preview:
The RC1 of the website can be found here: Karambastereo / La mejor musica Latina
Nice to have:
My most important request would be to be able to access the playlist files also via FTP. This would save a hell lot of time and enable to have a more ID Tag oriented file structure on the cloud meaning specific naming conventions for folders.... Anyway access those playlists would be awesome. A documentation for the structure would be also fantastic - but some reverse engeneering would also do the job for me.
The following are just some suggestions which I found out during implementation and using your service:
Clear API Documentation, kind of Github + Swagger; feature request and bugtracking included.... As far as I can understand from your API integration docs, endpoint and response header - it's not public yet...
And....
If anybody is interested how it's implemented on our website (RC1), I'm happy to give acces to the Github Repo
Thank you and once again 👍👍👍
This is possible: https://www.radioboss.fm/radioboss-cloud/ftp-uploads/
The API is very basic at the moment, you can find more about it here: https://www.radioboss.fm/radioboss-cloud/api/
If you need more capabilities, feel free to let us know, we're open fo suggestions, more API commands can be added.
Your web site is nice looking by the way, good job!
yeah but not playlists - so far I can't see those I've created over the WEB UI.
would be cool if you could change the header to Access-Control-Allow-Origin: * would be cool; but I can understand that it could open the door for some 3rd party embadding...
the info you provide is more than suficent- thanks!! When the API is stable I'll change the endpoint and parsing, at the moment I'm using:
https://c9.radioboss.fm/w/nowplayinginfo
Thanks I'm finishing documentation and cleanup. I'm using a contininous delevery pipeline on this early stadium... who knows :cool:
[Edit]
the initial documentation here
Playlists have special treatment because internally they include full file paths based on the server directory structure. Currently it's only possible to manage them from the UI. We'll consider other ways in the future, but it's not an immediate priority.
Makes sense, we'll see if adding this is possible without compromising security.
The API is stable in the terms that it will not be changed, so any new updates will not break backwards compatibility. Internals like w/nowplayinginfo could be changed, however.
RadioBOSS Cloud 0.9.3 beta
Fixed "Web port link" listener IP address was incorrect in the reports. If you use "web port links", please switch server type to "Icecast KH" in Settings/Advanced. If you already use the Icecast KH server, please restart it from the System area (click the "Restart Server" button).
What would be good if you could in scheduler is turn parts off and on from the index rather than clicking into each one as I’m trying to do Xmas and nye but don’t want to mess up all the normal events or bypass the lot to over ride it foe Xmas day say or nye or set up a timer to do it all in advance and stop current events.
Maybe 2 schedular s so we can turn one off and the other on for Xmas or NYE
You can use event groups - set the group name for the event (s) and they will belong to a group. You can also drag and drop files between event groups. A group (as a whole) can be enabled and disabled.
We don't have a tutorial about it, creating a group is simply entering its name in the scheduler event properties.
Hi, could you provide the feature to show the next song? as there is already a feature to show on a web page the last ones already played.
