I'm sorry for the disinformation, did not notice that it's about RadioBOSS CloudGreat do you have a tutorial
Yes, a new widget will be available soon.could you provide the feature to show the next song?
Typically the reason for it is either: a track from this folder is currently playing, or it's due to a rare bug in FTP where it locks the file for some time. In case of FTP, wait for 1-2 days and it will resolve by itself. We're working on a better solution for this.I always come across this error when paying for folders or files, they posted here saying it was resolved but I can't delete it.
It would be great if you could edit tracklists afterwards.
I would also like to see only the search results displayed when using the search function. Currently, because all titles are still displayed, the whole thing seems quite confusing.
I believe it is not the fact that the audio is playing, because I delete files even though they are playing and there is no problem.Typically the reason for it is either: a track from this folder is currently playing, or it's due to a rare bug in FTP where it locks the file for some time. In case of FTP, wait for 1-2 days and it will resolve by itself. We're working on a better solution for this.
It's still scheduled to be added. There are lots of other things that were not planned but we had to address like performance issues, various crashes etc. The quality comes first, and after all quality issues are fixed we move on to adding new features.Is there any news about this in the meantime? You had promised a year ago that these features will come soon.![]()
There are two cases when deleting a file or a folder may fail: the track is playing or the track is open in FTP (and, sometimes, after you work with FTP some files will remain locked for certain amount of time, it's a bug in FTP implementatrion that we will address soon).I believe it is not the fact that the audio is playing, because I delete files even though they are playing and there is no problem.
Thank you for this additionRadioBOSS Cloud 0.9.4 beta
What's new
Track normalization can be accessed from the Media section. In order to normalize tracks, navigate to the folder and click the Normalize button in the files list. All tracks in the folder will be normalized in the background. To see how many tracks are left for processing, press the Show Status button at the top (queue size of zero means that all tracks are processed).
- Added Track Normalization feature. Normalizing is used to ensure that all music tracks are played with the same volume.
RadioBOSS Cloud uses EBU R128 standard to determine loudness and set the level correction. Normalizing does not change or re-encode music files. Any level corrections are reversible and do not reduce sound quality.
Normalization is only available on the Medium plan and higher. It's not available on the Small plan.
Thank you!!!! Great feature to have.RadioBOSS Cloud 0.9.4 beta
What's new
We set the default to -9 LUFS, which more or less corresponds to non-normalized files (so if you have some tracks that are not normalized, they won't be different in the level a lot). You can use other if you find that the music tracks play too oud or too quiet.But, please suggest what target level we shud normalize.. is default -9 is good enough
I don't see how this is possible. If you have an event to run at :55, it will run. It can't run too many or not enough - I'm not sure what this means actually1st way - I made hourly playlists and placed them at :55 *results were inconsistent. Playing too many or not enough.
You can check the Logs section to find what was started and played, and when.2nd way - I used the scheduler to play random files out of a specific folder at :25 then had RadioBoss Cloud play again in 30 min. This was way off!
The Logs will show why those are skipped.It is better but still ends up skipping some ads.
Thank youWe set the default to -9 LUFS, which more or less corresponds to non-normalized files (so if you have some tracks that are not normalized, they won't be different in the level a lot). You can use other if you find that the music tracks play too oud or too quiet.
One possibility is that event start time is not configured properly e.g. you use "Repeat every" or week days and event starts more times than needed. Another way is if you use the "Insert tracks as regular music tracks" option, so it's not removed after playback from the playlist and continues to play.Some of my morning show tracks are intermittently playing throughout the day, even though I have set them SPECIFICALLY for their spot in the morning. Do you have any idea of what's causing this?
But that's just it. There are no repeat or insert parameters placed on the tracks. They are set to run at their appropriate times on the days we have them setOne possibility is that event start time is not configured properly e.g. you use "Repeat every" or week days and event starts more times than needed. Another way is if you use the "Insert tracks as regular music tracks" option, so it's not removed after playback from the playlist and continues to play.
