RadioBOSS 6.1 [beta]
When choosing color for font, you click on the RGB colour palate on the right to select the RGB amount you want.
This is a standard system dialog, it's what Windows supplies, it's not customized or modified in any way. In your case I guess the problem is with the slider on the right - it's set to max brightness which results in white color.
I have moved the post about licensing to the relevant topic: https://www.djsoft.net/community/threads/changes-to-software-update-policy.7564/
99% this was the cause. RadioBOSS creates a temp file with "spoken" text and it's very likely that antivirus didn't allow it to be created. The next update will provide (where possible) a detailed error message why TTS isn't working.
Please run the generate command as a separate event. It doesn't work properly sometimes when inserted into the playlist.
Please send the report file for this day, maybe it'll shed some light on what happened.
You should use the "Do not repeat track title" option for this.
How long did it run? I have tested on an instance that runs for more than a week, and the toolbar works properly there.
Done this using the "Do not repeat track title" option. It has spaced them into about once every 2 hours, on rare occasion, which I can live with especially since the Playlist Creator appears to be using more of the library then it has in the past.
About 30 minutes, and/or after coming out of the screensaver. The icons are "displaced" and moving the windows mouse pointer to the right of the last visible icon will bring up at least 1 "tooltip" on the empty area that can be clicked for that icon selection...if it were visible... "Broadcasting". selection.
“Playlist Creator appears to be using more of the library then it has in the past.
When creating a playlist or track list is it preferable to select from a library folder or the actual file folder? Does it make any difference which one is used in the playlist setup?
Cosa c'è di nuovo
  • Funzionalità di rendering su file (mixdown): rende una playlist in un singolo file, consente di creare spettacoli preregistrati
  • Forma della curva di dissolvenza incrociata configurabile (lineare, parabolica)
  • Aggiunto terzo ingresso (Ingresso 3) che può essere utilizzato in aggiunta ai due ingressi esistenti
  • Intro automatico: aggiunte nuove condizioni (valutazione, durata), aggiunto un secondo blocco di condizioni
  • Aggiunte nuove schede playlist: richieste di brani, coda di riproduzione
  • Letto del microfono: musica di sottofondo per il microfono quando non viene riprodotto nulla nella playlist
  • Microfono: opzione per avviare la traccia successiva dopo lo spegnimento del microfono (fare clic con il pulsante destro del mouse sul pulsante MIC)
  • Il titolo della trasmissione personalizzato è incluso nella colonna Titolo traccia della playlist
  • Ricerca playlist migliorata: ora mette in evidenza tutti i risultati
  • Il titolo di trasmissione personalizzato (per flussi di rete, input di linea, ecc.) Ora include la cronologia tra cui scegliere dai titoli precedenti
  • L'API può essere utilizzata tramite il protocollo HTTPS (richiede l'aggiunta di un certificato)
  • È possibile selezionare colori personalizzati per le schede della playlist
  • Le schede della playlist possono essere trascinate con il mouse
  • Rapporti: il protocollo FTPS può essere utilizzato per caricare nowplaying e artwork
  • Supporto WASAPI per dispositivi di output Prelisten, Cart wall e Jingles
  • Stile: la dimensione dell'icona della barra degli strumenti può essere regolata (Impostazioni->Visualizza->Stile)
  • Sono supportati modelli di file NowPlaying personalizzati
  • Elenco tracce: opzione artista separata per migliorare la protezione dalla ripetizione quando sono elencati più artisti
  • Elenco tracce: visualizza e modifica la posizione nella sorgente della traccia per la selezione "In ordine" e "Serie"
  • Miglioramenti nella staffetta
  • Notifiche e-mail: il nostro servizio di posta elettronica può essere utilizzato al posto di SMTP, non richiede configurazione
  • Aggiunta l'opzione "Disattiva la scheda audio del monitor durante il preascolto" nella finestra di preascolto
  • Il microfono può essere pre-ascoltato (fare clic con il pulsante destro del mouse sul pulsante MIC)
  • Finestra di registro: aggiunto un filtro per mostrare solo i brani riprodotti
  • API: gli eventi dell'elenco "scheduler" segnano l'ultimo evento iniziato
  • API: "encoderstatus" include il conteggio degli ascoltatori per ogni codificatore
Pianificatore annunci
  • Sistema di profili: è possibile creare un numero qualsiasi di profili per gestire separatamente diversi tipi di annunci (commerciali, sociali, politici ecc.)
  • Modificato il modo in cui vengono gestiti gli annunci, ora gli annunci non sono legati ai file sul disco
  • Aggiunta opzione configurabile: gruppo per evento "adsupdate"
  • Mescola annunci: tiene conto delle priorità degli annunci
  • Protezione dalla ripetizione di base per tracce pubblicitarie alternative
  • Ripeti protezione per separatori
  • Aggiunta l'opzione "probabilità separatore"
  • Aggiunta l'opzione evento programmato "Inserisci spazzatrice"
  • Risolto: gli sweeper elaborati in modo errato quando vengono utilizzate tracce alternative
  • Risolti bug con elaborazione intro/outro
  • Risolti bug minori di gestione degli annunci da remoto
Libreria musicale
  • Mostra la durata e il conteggio delle tracce selezionate
  • Visualizzazione della cronologia di riproduzione migliorata
  • Il comando "makelibrary" aggiorna effettivamente la libreria invece di ricostruirla completamente
  • Opzione aggiunta per cambiare il colore di sfondo dell'elenco
  • Aggiunta la colonna Indice all'elenco
  • Date di inizio/fine vuote in blocco per le tracce
  • Aggiunta l'opzione per cancellare il conteggio delle riproduzioni, la cronologia dell'ultima riproduzione e quella riprodotta per i brani
  • Migliorata la gestione dei tag utente; funzione di pulizia dei tag per rimuovere i tag inesistenti dalle tracce
Pianificatore
  • Nuove opzioni aggiunte nella procedura guidata di pianificazione
  • Esteso il comando "clearplaylist": "clearplaylist up" per rimuovere le tracce sopra la traccia in riproduzione
  • Aggiunti comandi per abilitare e disabilitare i singoli eventi per nome
  • Colonna "Manuale" aggiunta all'elenco degli eventi, contiene l'ora in cui l'evento doveva essere eseguito quando la modalità manuale è abilitata
Sistema di richiesta dei brani
  • Miglioramenti nella finestra dell'elenco dei brani richiesti
  • Le richieste di brani vengono registrate e conservate nell'elenco per riferimento
  • Il messaggio di richiesta è disponibile con la variabile %requestedmsg nelle notifiche
Strumento di monitoraggio
  • Mostra la durata della traccia tra l'inizio e la fine
  • Tasti di scelta rapida (F2-F11) per impostare i marker
  • Mostra il valore del tempo per la posizione corrente del cursore
Segue Editor
  • Mostra Intro e Outro se impostato per le tracce
  • Risolto errore di riproduzione ritardata su alcuni computer
  • Risolti molti problemi minori e miglioramenti generali della qualità
Generatore di playlist
  • Tiene conto dei punti Mix personalizzati impostati per le tracce musicali
  • Miglioramenti nella finestra di modifica della categoria
Riproduzione video
  • Rilevamento esatto della durata del video quando viene utilizzato il plug-in video
  • Sincronizzazione AV migliorata
  • Aggiunto il supporto per i file Webm
Opzioni avanzate aggiunte
  • Rilevamento degli errori del flusso di rete
  • Ricerca playlist sempre visibile
  • Controllo dello stallo del dispositivo
  • Algoritmo di disegno della forma d'onda
  • Verifica il silenzio durante l'inoltro di un flusso di rete
Correzioni di bug e miglioramenti minori
  • Più eventi "genera playlist" possono interferire tra loro
  • Nowplaying viene aggiornato quando viene utilizzato il comando API "setcasttitle"
  • Lo stile della finestra selezionato è contrassegnato nei moduli aggiuntivi
  • Interfaccia utente migliorata per selezionare il colore del gruppo di eventi pianificati
  • Risolto un bug con i commenti nella playlist
  • Bug minori risolti con i colori della playlist
  • Lo strumento di tracciamento può essere chiamato per gli articoli del muro del carrello
  • A volte le informazioni sui tag per OPUS non venivano caricate
  • Risolti bug nell'elaborazione del teaser
  • Risolti bug nell'elaborazione delle regole di introduzione automatica
  • Risolto: i brani riprodotti tramite il comando "getfile" a volte non venivano registrati
  • Risolto: il video in sovrapposizione interrompeva la riproduzione del video nella playlist principale
  • Risolto: il comando "stop" terminava erroneamente la traccia al punto Mix
  • Altri bug risolti, miglioramenti minori
Chiave di licenza:
Se sei un utente registrato e il tuo abbonamento di aggiornamento non è scaduto, utilizza la tua chiave.
Per richiedere la chiave di licenza gratuita del beta tester, compila questo modulo: https://www.djsoft.net/enu/beta.htm
La chiave gratuita scade il 31 gennaio 2022.
Scarica
RadioBOSS 6.1 beta:
x86 https://dl.djsoft.net/beta/radioboss_beta_6.1.0.3.exe (26/11/2021, 31 MB)
x64 https://dl.djsoft.net/beta/radioboss_beta_6.1.0.3_x64.exe (26/11/2021, 35MB)
Si prega di pubblicare bug e richieste minori in questo argomento e creare un nuovo argomento per richieste o segnalazioni più complesse.
Chiunque abbia contribuito riceverà uno sconto significativo, fino al 100%, quando verrà rilasciata la versione finale. Si prega di contattare sales@djsoft.net per quanto riguarda lo sconto.
would it be possible to also preserve the state of the local audio output as in the screenshot below
it does not preserve this at the moment, so if RB crashes it comes back up playing the audio. I have to switch my speakers off just in case this happens during the night. I was woken early hours of the morning one time with music playing from my studio
HOLA MI NOMBRE ES MIGUEL VAZQUEZ .... ME GUSTA RADIO BOSS HE PROBADO ESTA VERSIÓN BETA.. Y A MEJORADO MUCHO -- EN MI CASO PARA MI LE HACE FALTA 2 COSITAS 1. EN EL REPRODUCTOR AUXILIAR .. QUE SE PUEDA ADELANTAR LA PISTA QUE TENGA UNA LÍNEA DE TIEMPO ASÍ ... EL USUARIO PUEDA ADELANTAR LA PISTA EN CUALQUIER SEGUNDO ...... 2 EN SU REPRODUCTOR DE VIDEO .... SE QUE SOLO REPRODUCE PERO SI LE SACAMOS EL JUGO. AL RE PRODUCTO CUANDO UN TRACK ESTÉ SONANDO QUE SE DESCARGA EL VIDEO DE LA NUBE .. ASÍ LO VEMOS EN EL REPRODUCTOR.... Y NO ESTEMOS BAJANDO LOS VIDEO .... ESO Y ES UN EXCELENTE PROGRAMA GRACIAS ESPERO SU RESPUESTA ATENTAMENTE MIGUE LVAZQUEZ
El navegador integrado en la radio del jefe no me funciona. descargue el complemento pero aún nada, ninguna solución
In Ads Scheduler our settings are as follows:
When viewing the event properties, the 'Remove previous schedule from playlist' option isn't carried over
I think this is a mistake on our part for having the settings set that way as it defies the logic that applies with both settings being set at the same time, however the expected behaviour would be for the checkbox to auto unselect from the 'losing' checked option (similar to how it does if you click on the event itself and click 'Remove previous schedule from the playlist, when it already has 'if there are tracks from the schedule in the playlist, enqueue' checked)
It doesn't reproduce here - the toolbar stays correct even after months of operation. Looks like this is specific to your computer.
No, it doesn't matter.
I'm making a language file, who can I send it to?
You can send it to support@djsoft.net
You can set the volume level to zero, this way it will be preserved.
Correct, those options are mutually exclusive - you can't enqueue after scheduled events and also remove them. Ads Scheduler will be made to work similar to event editor in RadioBOSS that unchecks the checkboxes automatically.
djsoft :​
I would add the possibility of showing the program screen from the director to the studio, Cool and useful option to show what the Sound Engineer is doing on the screen I have a few more nice ideas but it's in due time :)
Thank you for the suggestion, but this feature doesn't really fit into our software profile and is not really about radio automation.
Radioboss crashed yesterday and restarted I have no idea why here are the reports
  • Crash Reports.zip
