start of multiple encoders
is there a way to set the start of multiple encoders in one command like connect 1, 2, 3 or disconnect 1-2-3?
If you only have those three encoders, you can simply use connect and disconnect commands - they will start/stop all encoders. If not, then you'll need to use multiple commands, one for each encoder.
Currently have 12 encoders of which sometimes 6 or 7 simultaneously
There are situations where I want to stop 3 or 4 of them at the same time, the others should keep running or I want to start 3 or 4 at the same time.
with a command connect 1,2,3,4,5,6 or the command disconnect 2,4,6 i could control them from the cartwall
now i have a button for each encoder, but i wanted to combine them in one button
Thank you for the suggestion, we'll extend those commands to allow specifying multiple encoders.
what is the better encoder solution to broadcast more than 1 live radio using different sources (audio capture) within one computer?
Thanks!
Thanks!
You could start several RadioBOSS instances.
You just have to install the RadioBOSS several times under a different name, for example
RadioBOSS1
RadioBOSS 2
RadioBOSS 3 and so on :-)
