FREDERICVELU
Ok, group members,
here is the problem :
RadioBoss is on a laptop (Lenovo L340 17 API) + Omnia.9 PTN i remote control my laptops (i have different program streams - i mean different webradios)
When the lid of the laptop is open, Teamviewer is working fine and all softwares are working fine !
But when i close the Lid of the laptop (as the laptop is set to continue working when the lid is closed) everything is also working fine...
EXCEPT RADIOBOSS !
for some reasons, the main window of RadioBoss (radioboss.exe) doesn't draw or redraw... and is frozen on maximising so that i can't access menus and generate new playlists... (Again, this is the only software behaving like this ! Omnia.9 PTN interface works prefectly and all the meters are moving...)
What can be the problem ? is it a RadioBoss problem ? a teamviewer problem (i will contact them too for that) or a Graphic Driver problem ?
i actually have no workaround...
Did someone faced the same problem ?
Can Dmitri investigate that problem ? (if you've got time - it's not urgent...)
Thanks in advance,
Kindest Regards
EXCEPT RADIOBOSS !
Thanks in advance,
Kindest Regards
