ORBITA HIT
Hello friend, if I can help you.Cuando programo los datos de tiempo los tira de la lista de reproducción pero no lo reproduce automáticamente tengo que configurarlo manualmente porque lo pone en la lista de reproducción y detiene todo y tengo que ponerlo en reproducción manualmente cuál podría ser el problema
I have a folder called TEMPERATURE
inside the folder, another subfolder Humidity (within all the files HUM50, HUM51, HUM 52 and so on from 0 to 100)
I have another folder with the Temperature (inside TMP0, TMP1 and so on. By the way, also TMP-1, TMP-2 for negatives)
Mira creates a playlist with the following:
1º/ TMP?temp.mp3
2º/ HUM?humidity.mp3
You can put the 2 things, or only temperature, according to your interest.
Save as list temperature.m3u8
To finish, you create an event in the scheduler that executes that list temperature.m3u8
you will see that if you have for example
17 degrees and 60 humidity
It will play automatically according to the real information
Important other event wiht command:
weather Ciudad, Pais ( weather Madrid, ES)
Do you have a tutorial here:
https://www.youtube.com/watch?v=tVDspfPCwns
