This command doesn't work when it's in the playlist, it only works if it's a single command in the event, or it's a multi-action event and this command is the first action. This is a limitation.I found with the most recent update that CueNextOnEnd does not work when inserted in the scheduler as an event but it does work when inserted as a multiple followed by a track. Is this by design or a bug?
Can you please specify what function needs explaining?Perhaps a tip to make some more videos with explanations of new functions.
The command fades out the current track, but after finishing the fade and starting the new track, the track that ended is heard again at full level for approximately half a second.next 10000 CueNextOnEnd
Hello Dmitry, I have the following command
This is not new, it happens approximately 40% of the time, but it is quite messy on the air.
Thank you, this will be checked.The command fades out the current track, but after finishing the fade and starting the new track, the track that ended is heard again at full level for approximately half a second.
Does it always happen or only occasionally?We have also experienced this problem and avoid using the command at the moment...
