Can you please provide more details about it? The latest version considers the "Broadcasting title" is it's set for the file type, it also considers "broadcasting title" as it's set for the playlist item (e.g. line input).
It is not possible to change the name of the "Broadcast title"
I changed the name but it doesn't appear in the "playlist"
Or is it not possible to see it in the "playlist"?
Of course, it's the only solution I've found so far.Why use Ads Scheduler for it? You can run those items using separate events. If you need ads scheduler, I think you can utilize the intro/outro features, they allow using playlists.
I also have another concern, I don't know if it's a bug in the system, but in previous versions you could run DTMF tones without having to add a schedule, is that okay?
