Could the calculation of days be added to the "last played" column or tag? example: 03/20/2024 (7 days ago). This in all areas: track info, search, playlist (tooltip), etc.
Updating the request for this feature a bit, I saw some different examples and it would be good to consider the formats of how "last played" would be displayed (in some areas like Track Info), in addition to the "played approx. same" warning time now"
example:
Last played:
Today(6:32 a.m.)
10 days ago (5:57 a.m.)
21 Days ago(6:50 a.m) !played approx. at the same time as now!
Yes, makes sense - simplify date display and leave time. I'm not sure if it needs to add any notes like "same time as now" - guess it's already obvious looking at the time. The hint box should stay compact, for aesthetic purposes
I recently saw that a metadata process was implemented in Radio Caster that is very useful for replacing titles. Is it possible to implement this feature to edit track metadata or properties in the music library? And also an option to convert file name to title and artist? and vice versa?
