Active Playlist
djrodneyallen
Hi, I was wandering if there is anyway to schedule an active playlist? for example say I wanted to schedule a playlist for the overnight from12:00am to 6:00am and the switch back to a master playlist is there anyway to do that?
There's a command to switch active playlist tab: playlist TABNAME:
https://manual.djsoft.net/radioboss/en/scheduler_commands.htm
Another way would be to not change the tab, but simply schedule another playlist. You can probably add "Duration limit" to make it end after a fixed amount of time.
