Music Library freezes when removing Dangling .rbdata
Altec
Hi Dmitri,
I hope you spent a beautiful summer and some vacations at this occasion.
I noticed a database freeze when I'm using the cleaning metadata tool to remove useless old .rbdata.
The music library freezes, but the operation is working perfectly in background because at the end I have the operation complete windows, I think it's just a timeout operation in the software to set by your side. it's surely due to my wild libraries
Best regards
Altec
The entire operation is performed in the background and should not freeze the UI, we'll check this.
As it turned out, it indeed could become unresponsive (not freeze, as the task is performed in the background and eventually it'll finish), the next update will have this improved, with a proper progress bar window.
