Unfortunately, no - it can only send the Ads to one remote computer.Is there any way that in "create playlists and events" with the remote option ON, have the possibility of entering more than one API address? My situation is that I have 2 PCs to which I want to send the same information automatically.
It's really designed to manage a single remote instance, so I'm afraid there's no real way to send it to two computers. Do you use the adsremote command or you update ads manually?So, tell me.. is it possible to send manuaylly a adsremote command to do that?... if yes.. could you send me an example?
When you click the Run button, it performs export operation. adsremote command is not involved here, because it's different thing (it's a command in RadioBOSS's scheduler).We are using this option to send ads to the "On-Air" PC, but, I suppose that when run is clicked, an adsremote command is executed with all the parameters. Is that so?... can you know how is that command?
The same situation for usSame ads to multiple computers in my scenario
It's scheduled for one of the major updates, probably RadioBOSS 7.2.Hey there, do you have an ETA on this?
