How to configure AutoIntro
ibek95
Hi Dmitry,
what must I set so that the previous track (right before) AutoIntro is fully played out or at least til the mixpoint? I sometimes get confused where is the correct place to set this (general? or in AutoIntro itself?) I have RB 7.1.4.0.
Thanks and have a great weekend.
Tre track is played up to its Mix point then another tracks starts, and the track will continue to play until it fades out. Auto Intro does not affect this, only crossfade settings.
Ok and how can I reach that specific the song before AutoIntro is played out (instead up to its mixpoint like usual)?
Tracks are mixed according to crossfade settings: https://manual.djsoft.net/radioboss/en/crossfades.htm
Auto Intro is positioned according to the settings specified in the auto intro rule.
Next track starts playing at Mix point of the playing track. Then Auto Intro will play - according to when it's supposed to play (as specified in the rule settings).
But this means I can't make a seperate crossfade-rule for AutoIntro? Because AutoIntro can't have an own category, I guess.
Song before AutoIntro should be fully played out, but this should be only the case if AutoIntro is next.
Otherwise it should have the normal crossfade-settings/mixpoints.
This here in AutoIntro:
"Position on track - set the auto intro jingle position on the music track. Start at and End at set the position type: where jingle should be started, or where it should end. Then the time value is set, in seconds, or it can be a special value: Intro or Fade In. For instance, if the position is set to End at: Fade In the jingle will end its playback at the time when the underlying music track finishes fading in. If position is set to End at: 3.5 the jingle will end 3.5 seconds after the start of the music track."
There are 2 things to chose on "position on track". I have "end at: 2 sec" right now. Nothing at start at ... Can both (start at/end at) be configured? Why aren't there 2 seperate fields? It is confusing that you have to switch between those two.
And what must I set then at "start at" so that the song before will be played full?
Yes, currently this is not possible, songs are mixed the same regardless if the Auto Intro presents or not.
If you set both of them, Auto Intro track may be shorter or longer than the interval specified, and this will sound bad almost all the time.
You set what is important, if you set start at 0 then AutoIntro will simply start together with the music track. If you set end at 0, it will start some time before track's supposed to start, so that it will end and the music start playing.
Ah sorry, I didn't mean AutoIntro - I meant teasers which are planned with an event https://manual.djsoft.net/radioboss/en/index.html?teasers.htm
Teaser is a totally different feature, it doesn't have start at or end at because it's a separate playlist element (unlike autointro that's attached to existing items).
