L lughsan Active member Sep 29, 2025 #1 Hello Dimitry, how are you? I report an error in the work areas. Work windows do not save their position. When you expand or reduce the RB overview window, its position changes. Attachments CAP1.PNG 21.6 KB · Views: 198 Cap2.PNG 29.2 KB · Views: 195 Cap3.PNG 20.8 KB · Views: 162
L lughsan Active member Sep 29, 2025 #2 I have another question: A message appears in the left corner asking me to update my version. How can I disable it?
D djsoft Well-known member Staff member Sep 29, 2025 #4 lughsan said: I report an error in the work areas. Work windows do not save their position. When you expand or reduce the RB overview window, its position changes. Click to expand... What RadioBOSS version do you use? Can you please make a screenshot of entire window before and after this bug?
L lughsan Active member Sep 29, 2025 #5 tomimatko said: Help > Automatically check for updates Click to expand... I disabled that option and the message still appears.
L lughsan Active member Sep 29, 2025 #6 djsoft said: What RadioBOSS version do you use? Can you please make a screenshot of entire window before and after this bug? Click to expand... RB 7.0.8.0 windows7 32 bit I hope the error is now better understood. When RB is left next to the window (left or right side) for a few minutes, it generates the error. Attachments CAP1.PNG 86.3 KB · Views: 157 Cap2.PNG 822.2 KB · Views: 204 Cap3.PNG 87.3 KB · Views: 172
D djsoft Well-known member Staff member Oct 1, 2025 #7 lughsan said: I disabled that option and the message still appears. Click to expand... Please restart the software, if the message appeared it will not go away. lughsan said: RB 7.0.8.0 windows7 32 bit Click to expand... This is older version, please check how this works with the most recent version. There are lots of changes between the major versions.
