CLOUD: Is there a simple way to check for duplicates?
rhaney21
Is there a simple way or a suggestion on how i can check to see if any of the folders have duplicates? I have around 1,500 spread out in about 10 folders and I just know that I have a few duplicates in each folder. Anyway to see this?
I keep a copy of all our music on local storage and then use FTP to 'sync' the files and folders to the Portal.. This way, I can run various scripts on the files for updating metadata, etc.. Seems to be the best work around to manage the media files.
There's no such a feature, I'm sorry. RadioBOSS Cloud supports FTP, so maybe you can look for a software that will check folder contents over FTP and search for duplicates.
Yes, this is one of the reasons FTP is supported in RadioBOSS Cloud.
