CLOUD: Is there a simple way to check for duplicates?
rhaney21
Is there a simple way or a suggestion on how i can check to see if any of the folders have duplicates? I have around 1,500 spread out in about 10 folders and I just know that I have a few duplicates in each folder. Anyway to see this?
I keep a copy of all our music on local storage and then use FTP to 'sync' the files and folders to the Portal.. This way, I can run various scripts on the files for updating metadata, etc.. Seems to be the best work around to manage the media files.
There's no such a feature, I'm sorry. RadioBOSS Cloud supports FTP, so maybe you can look for a software that will check folder contents over FTP and search for duplicates.
Yes, this is one of the reasons FTP is supported in RadioBOSS Cloud.
Why not make it so in RadioBoss Cloud when we click on the "/" directory icon in the media section, it just lists all of the songs in all of the folders below it??
It's not how file managers supposed to work. The \ folder shows what you have in the root folder. Same as it works in Unix systems or in Windows when you open drive root.
