Issue with Drag-and-Drop When Reordering Track Lists in RadioBOSS
originalprod
Hi Dimitri, hi everyone.
I have a company that provides technological solutions for radio stations. We offer classes and consulting, including helping stations transition from ZaraRadio or ZaraStudio to RadioBOSS (in spanish).
Yesterday, during a consulting session, I ran into a technical issue.
My client’s playlist uses track lists because he has his music organized in folders, just like he did in ZaraRadio. For me, the transition was easy, and I created all the track lists. However, when I tried to sort them, it was impossible to do so using drag and drop. When I drag and drop the track lists, RadioBOSS starts selecting other items. I don’t remember experiencing this in previous versions.
I recorded a video from my screen replicating the issue: https://youtu.be/VDN7PwdJZLQ
Thank you very much for your help and support.
Interesting, but this does not reproduce here. Are you sure the mouse is not faulty? It theoretically can happen if left mouse hold is not registered properly (it's on and off) then it can select items while auto-scrolling.
The mouse is not faulty. I have tested the same procedure on 4 different computers (Windows 10/11), using both mouse and trackpad, on desktops and laptops.
I tested it again, and it seems the issue happens when the user wants to scroll down faster with the mouse pointer, they move the pointer outside the playlist area and then bring it back up. When doing that, RadioBOSS starts selecting multiple items instead of allowing a normal drag-and-drop.
This can be the cause as it's registering a mouse leave event. In this case, I suggest keeping the mouse in the playlist area while dragging. And also if you need to move tracks further into the playlist, it may be easier to cut-paste them instead of doing a lengthy dragging.
