Playlist Generator Pro : use the Last Played tag when do not update playcount and last played option is checked
Altec
Hi Dmitry,
In some of my studios (particularly for certain web radio stations), I have checked the ‘do not update playcount and last played’ option. This reduces the amount of work required by the hard drive to update my .rbdata files. It also allows me to have several studios on the same database without the last played tag causing confusion between studios.
I was wondering where the ‘use the last played tag’ option gets its information from? Perhaps from the tracks.db file ?
If I have disabled the last played count, is this option useful, or is it pointless?
Thank you in advance
If you have disabled the playcount update tag, it also prevents writing the last played tag as well, so any features that rely on this tag, will not work as intended.
The amount of the data written is so low, it will take a millennia to wear out even the cheapest SSD drive.
So this information is written only in the Rbdata and if this feature is disabled, it is useless to activate use the last played tag ?
Not if you have more than 30 studios running on Hyper V on a RAID 1 HDD setup...
Can we imagine a different way to store this information because I have another problem, I wanted to use one database for 20 RB studios, but the problem is with last played tag, if the song is played on differents studios they will update the last played tag so it will perturbate the generation of each one, leading a particular studio to believe that the track has already been played on it, when in fact it has not.
Each studio that connects to the database should be able to store playcount and last playback information specific to each radio station that connects to the database, you see what I mean ?
Kind regards, and thank you for listening to us and taking my suggestions and requests into consideration. It is truly appreciated.
Altec
It is, yes, as the information is not written in the first place, it can't be used.
Even in this case there will be no noticeable drive wear, as size of each .rbdata file is ~1KB. Most of those writes stay in the cache for a long time and only flushed to the disk occasionally.
This is a feature planned for the future versions, to allow storing the playcount/last played separately for each studio, while having all other data shared.
Wonderful can't wait for this feature Dmitry !!
You're the best
Hi @djsoft is this was integrated or not yet ? Because I wanted to connect 3 studios on one Database for webradios and I'm not sure i can do it without playcount be disabled.
Currently not, it would require significant changes to database and operation, can only be done when a major update is developed.
argh ok.
Thank you Dmitriy, can't wait for that feature, because i can't globalize my databases until this feature is implemented.
Altec
