Musikbibliothek
DerPlotter
Hallo,
Ich verwende die RadioBoss Version 7.1.6.2
und wüsste gern wofür unten in der Bibliothek Anzeige der Bottom " Aktiviert " ist ?
Im Handbuch ist leider nichts darüber zu finden.
Für eine Antwort bedanke ich mich.
I'm taking the liberty of translating for the member "The Plotter" because I'm also interested in this!
Hello,I'm using RadioBoss version 7.1.6.2
and would like to know what the "Enabled"
indicator at the bottom of the library is for?
Unfortunately, there's nothing about it in the manual. :)
Hello (Hallo),
There's a checkbox next to "Enabled" (Aktiviert). When you check this box, you'll only see active tracks and you'll no longer see deactivated tracks in your music library.
For your information, it's possible to deactivate a track in the track's properties or in the Track Tool (Disable Song). This is a function used by Playlist Generator and Track List.
This, like the rest of the fields, is a filter. If you check it, only enabled tracks will be left in the list (the track that have "Disable track" option enabled, will be filtered out).
