Nomenclature of playlists generated by the Ads Scheduler
This command will update the playlists (.m3u8 files) and events in RadioBOSS's scheduler.
If you don't call this command or export manually from the Ads Scheduler, then the events/playlists will not be updated/created.
It will not replace because you didn't instruct it to, it will run the same ads over and over. Depending on your configuration, you should run the adsupdate command periodically (every day or every hour).
It's explained in the user manual: https://manual.djsoft.net/radioboss/en/automatically-update-ads-playl.htm
So that’s exactly what I was saying: adsupdate is essential, however when the screens are programmed manually there is indeed a problem, because if I activate the adsupdate command periodically, we cannot prevent RadioBoss from generating triggers in the studio’s scheduler.
In a complex scenario where we cannot use this system and instead have to chain several m3u8 detections, it becomes an issue that it reinserts the triggers into the scheduler again.
He should simply insert the scheduled audio files into the m3u8 files without creating schedules in the studio. Otherwise, there will be duplication between the manual schedule and the triggers that adsupdate inserts with each update.
This command is essential to ensure that ads are run when they are supposed to, and do not run when they are not (e.g. their End Date passed). So you have to run this command frequently. And, because this command manages the ads events, you should not make any manual edits to those events (and playlists), as any of those changes will be cancelled when the command is executed.
You can disable the "Add events to RadioBOSS Scheduler" option, in this case, it will simply generate playlists.
That is why I was drawing your attention when using scheduling both via Ads Scheduler and my internal systems at the same time with a complex scenario. There is then a necessity to obligatorily perform an "adsupdate", but it should be possible to tell it to generate only the m3u8 files and not set any trigger, because I manage them myself with my own parameters.
I have the same problem, and everytime when you generate the playlist this checkbox is Checked, very annoying to be forced to uncheck it at each time.
Thanks JeanXeb
Best
Second point: if I manually schedule my advertising breaks using variables like:
%yyyy%mm%dd_%h_%m_regie_adsscheduler_in_radioboss.m3u8
%yyyy%mm%dd_%h_%m_regie_A.m3u8
%yyyy%mm%dd_%h_%m_regie_B.m3u8
%yyyy%mm%dd_%h_%m_regie_adsscheduler_out_radioboss.m3u8
And inside those files the ad providers haven’t inserted any advertising blocks—so the m3u8 files (regie_A.m3u8 and regie_B.m3u8) are empty—yet in the scheduler I still ask it to perform actions to play regieA and regieB every hour with a delay of 1 minute 30 seconds to let the current track finish. The issue is that RadioBoss moves to the next track even when the m3u8 files are empty.
It would therefore be important to preload the m3u8 files and check whether they contain anything or not, so the program can continue normally when there is no advertising from either provider.
[deleted]
With manual operation, it won't happen, but adsupdate command will always add events.
Previous post was edited because the information there was not right.
The adsupdate command can be instructed to not add events to RadioBOSS, call it with the -skipevents parameter:
adsupdate -skipevents
This way, it will only update the playlists. It is documented here: https://manual.djsoft.net/radioboss/en/scheduler_commands.htm
Thank you for this good news.Unfortunately, and simply to be constructive, the RadioBOSS documentation is not always easy to understand, and it often requires your expertise to interpret the software’s behaviour. It would be helpful to update it and provide examples.Wishing you a very good day.
The -skipevents parameter is documented in the appropriate user manual section, where all other commands are also described. RadioBOSS is not a small software, as you see, and it has lots of features, so its user manual may look big at first. But it's structured so once you are familiar with it, it's easier to get around. Also, if you can't find anything, you can always ask here on the forums.
Yes a fresh update of Radio Boss Documentation could be really useful because some features explanations are missing !
Best Regards
It is essential for us to be able to export reports from ReportViewer via CMD or PowerShell, with the ability to specify the file type.
We are currently experiencing issues with our automated reports: whenever manual changes or specific filters are applied through the interface, it disrupts the log generation for our clients.
To mitigate these issues, we require a CLI-driven approach to define all export parameters. This will decouple our automation from the UI, eliminating failures caused by manual overrides and ensuring consistent delivery to our clients.
Thank you for your suggestion, we'll improve command line options for the Report Generator. Probably, it will be implemented as Profiles to allow simply specifying the profile, to avoid setting many parameters.
Thank you for your time and for considering my proposed improvement. The current solution is already quite good; the main issue is simply a settings conflict where one user’s changes can inadvertently stop an automated data retrieval process running via CMD or PowerShell.
Yes, that's why I think for command line use Profiles would be a better solution (a profile will contain all configuration for the report generator).
This part could be very interesting for me, I'm using a system to insert ads and when playlists are empty I have a next command and an error reported in the log :'(. It will be nice to have such an option to avoid insertion of an empty playlist into the playlist.
Best Regards
Where do those empty playlists come from? The ads scheduler has two options: create empty playlists (and corresponding events), or not create. In nether of those cases there will be an error, because loading an empty playlist is a valid operation.
Thank you RadioBOSS for taking my feedback into account and integrating it into your update. It works perfectly. Have a great day!
I would like more information about this new option, as I don’t understand how to use it. I haven’t found any details about it in the documentation :
Ads Scheduler
Remote export: allow specifying username
Which username are you referring to, exactly? How should the export options be configured?
Remote Ads Management operates using RadioBOSS API: https://manual.djsoft.net/radioboss/en/remote_control_api.htm
The API allows using a master password (with no username), and in previous version this was the only authentication method for the Ads Scheduler to send the ads.
Now RadioBOSS supports API users with limited rights, authenticated by username and password. To use this new feature, Ads Scheduler now allows specifying username as well.
