RadioBOSS 7.2 [beta]
What's new
  • Virtual Mixer Console (RadioBOSS Ultimate)
  • Changes in the design of the main window
  • Styles: new default styles and more options to configure the main window appearance
  • Layout management window (menu View > Workspace > Customize): quickly hide/show UI elements
  • Next Track display improved: shows track markup and waveform
  • New tab yype: Clock
  • Dayparting: set when a track is allowed to play (hours/days of the week); used in the Playlist Generator and Track List (RadioBOSS Ultimate)
  • Playlist: added "Icon" column to display custom icons defined for file types
  • Playlist: added Start Date / End Date columns
  • Streaming: option to send StreamURL tag in stream metadata
  • Weather data retrieval can now be configured in settings; retrieve by geo position
  • Added "Fade on Pause" option in Settings > Playback > Fading
  • Track List: track is not re-rolled if not necessary
  • Advanced options: millisecond precision for Track Tool, shift Mix Point
  • Show duplicates and other options are now protected with UAC
  • Auto Intro: improved probability processing for rules (checks if a rule can actually be used first)
  • Auto Intro: improved error handling and reporting; playback can now be stopped
  • File Explorer tab: user interface improvements
  • API Users: new permission "Remote Ads Management"
  • Emoji characters can now be used for tab names
Scheduler
  • Event expiration handling improved
  • Improved events list display
Playlist Generator
  • New repeat protection option: do not play tracks at the same time as yesterday (RadioBOSS Ultimate)
  • Scheduler wizard: set expected start time for a generated playlist
  • Improved random track selection when priorities are not used
  • Improved "Create Multiple Playlists" window
Ads Scheduler
  • Additional variables can be used in playlist name templates
  • Multi-select for ads in the list
  • Remote export: allow specifying username
  • Option to set names for created events
Track Tool
  • Extended track zoom limit
  • Auto Detect option to set Start/End/Mix points
  • Improved performance
Minor Improvements
  • Multi-select option for "Add Tracks from Playlist"
  • Fixed: weather data from OpenWeatherMap was sometimes incomplete
  • Waveform is now the default visualization
  • Extended gap killed dB limit
  • Accessibility: hotkey (Shift+F9) to focus the "Remaining Time" text
  • Fixed: Report Generator did not read profile settings when launched directly
  • Fixed sorting in Music Library for some columns
  • Fixed: commands were not executed inside a container
  • Fixed: pipe character was not properly displayed in Now Playing
  • Fixed: some HLS streams did not play
  • Fixed: exported artwork was not reset on stop
  • Improved high-DPI screen support
  • Fixed: waveform was not displayed for tracks longer than 30 minutes
  • Several options related to Stream Archive moved out of Advanced Settings
  • Fixed weather data display in dark themes
  • "Smooth Level Meter" option moved out of Advanced Settings
License key
The free key expires May 15, 2026.
RadioBOSS 7.2 beta
x86 https://dl.djsoft.net/beta/radioboss_setup_7.2.0.0.exe (2/6/2026, 35MB)
x64 https://dl.djsoft.net/beta/radioboss_setup_7.2.0.0_x64.exe (2/6/2026, 39MB)
I was eagerly waiting for the new version of RadioBOSS, mainly because of a feature we’ve been asking for years – Dayparting: set when a track is allowed to play (hours/days of the week).
And finally, here it is!
But then came a big disappointment: it’s available only in the Ultimate version, the most expensive one.
OK, I could understand if it were available in the Advanced version, although many of us expected it to be included in Standard as well.
Because this is not some kind of luxury feature – it’s one of the fundamental elements of radio automation.
saludos, felicitaciones esta muy elegante el Radio Boss. pero porque le quitaron la ventana de pista anterior.
es mi primera observación según que reviso le estaré haciendo llegar más sugerencias.
atte.
Ciro Yalli
si pudieran añadir en la dirección del URL. para que reproduzca el formato de YouTube, además en la escucha previa para escuchar yo bajo el volumen principal o master y también se baja el volumen de la escucha previa y todo queda en silencio si eso pudieran modificar o quiza me falta descubrir jjjj creo en las versiones anteriores no era así....... ¡Está muy bonito el mixer.
What's new
Scheduler
Playlist Generator
Ads Scheduler
Track Tool
Minor Improvements
License key
RadioBOSS 7.2 beta
Observations:
  1. It is not possible to assign an icon to the music file type.
  2. Some icons are not applied after saving the changes.
  3. Some icons are missing for elements such as: track list, containers, commands, and/or elements that are not file types.
Suggestions:
  1. In the playlist window, instead of configuring fonts and background colors for the current and next track, an icon could be added to indicate which track is next. This could help reduce visual clutter, as there are currently too many colors defined (at least in my case).
  2. In the additional workspace, the button or option to split the workspace into sections has not yet been added.
  3. When playing the song intro, a blinking text should be displayed indicating that the intro is being played.
  4. I think it would be better to set icons in a fixed way instead of using a column. That is, replace the fixed icons (such as the musical note) with user-defined icons. For programmed elements, two icons could alternate continuously: the user-defined icon and the programmed element icon. Alternatively, the current behavior could be kept.
  5. Could a kind of smooth transition be added to the playlist? When changing the current track, a transition animation could also be applied to the top panel.
Hallo
Ich habe die Version
RadioBOSS 7.2 [beta] getestet und mir ist auf gefallen bei dieser Version kann ich nicht mehr meine Netzwek Festplatten im Radioboss hin zu fügen. Leider hatte ich festgestellt das man das micro nicht mehr verändern kann und die Skala des Micro ausschlages nicht mehr vorhanden ist ,wie man es in der alten Version möglich war .Ich benutze Windows 11 pro. ich teste weiter​
Suggestions:
Regarding this suggestion, I think it would be possible to add the option to set an “icon”, in the same way it is set for “file types”, to the currently playing track and the next track. It should have the option to blink or remain fixed (only for the current track).
Observations:
  1. Some icons are not applied after saving the changes.
In this case, the icons are applied when I make an additional change, but if I set only the icon without changing any other option, it is not applied.
Hallo
RadioBOSS 7.2 [beta] getestet Leider hatte ich festgestellt das man das micro nicht mehr verändern kann und die Skala des Micro ausschlages nicht mehr vorhanden ist ,wie man es in der alten Version möglich war .Ich benutze Windows 11 pro. ich teste weiter​
