What's new
The free key expires May 15, 2026.
RadioBOSS 7.2 beta
x86 https://dl.radioboss.app/radioboss_setup_7.2.1.6.exe (5/19/2026, 32MB)
x64 https://dl.radioboss.app/radioboss_setup_7.2.1.6_x64.exe (5/19/2026, 36MB)
For the convenience of all members, please write your posts in English only. Thank you!
- Virtual Mixer Console (RadioBOSS Ultimate)
- Changes in the design of the main window
- Styles: new default styles and more options to configure the main window appearance
- Layout management window (menu View > Workspace > Customize): quickly hide/show UI elements
- Next Track display improved: shows track markup and waveform
- New tab yype: Clock
- Dayparting: set when a track is allowed to play (hours/days of the week); used in the Playlist Generator and Track List (RadioBOSS Ultimate)
- Playlist: added "Icon" column to display custom icons defined for file types
- Playlist: added Start Date / End Date columns
- Streaming: option to send StreamURL tag in stream metadata
- Weather data retrieval can now be configured in settings; retrieve by geo position
- Added "Fade on Pause" option in Settings > Playback > Fading
- Track List: track is not re-rolled if not necessary
- Advanced options: millisecond precision for Track Tool, shift Mix Point
- Show duplicates and other options are now protected with UAC
- Auto Intro: improved probability processing for rules (checks if a rule can actually be used first)
- Auto Intro: improved error handling and reporting; playback can now be stopped
- File Explorer tab: user interface improvements
- API Users: new permission "Remote Ads Management"
- Emoji characters can now be used for tab names
- Event expiration handling improved
- Improved events list display
- New repeat protection option: do not play tracks at the same time as yesterday (RadioBOSS Ultimate)
- Scheduler wizard: set expected start time for a generated playlist
- Improved random track selection when priorities are not used
- Improved "Create Multiple Playlists" window
- Additional variables can be used in playlist name templates
- Multi-select for ads in the list
- Remote export: allow specifying username
- Option to set names for created events
- Extended track zoom limit
- Auto Detect option to set Start/End/Mix points
- Improved performance
- Multi-select option for "Add Tracks from Playlist"
- Fixed: weather data from OpenWeatherMap was sometimes incomplete
- Waveform is now the default visualization
- Extended gap killed dB limit
- Accessibility: hotkey (Shift+F9) to focus the "Remaining Time" text
- Fixed: Report Generator did not read profile settings when launched directly
- Fixed sorting in Music Library for some columns
- Fixed: commands were not executed inside a container
- Fixed: pipe character was not properly displayed in Now Playing
- Fixed: some HLS streams did not play
- Fixed: exported artwork was not reset on stop
- Improved high-DPI screen support
- Fixed: waveform was not displayed for tracks longer than 30 minutes
- Several options related to Stream Archive moved out of Advanced Settings
- Fixed weather data display in dark themes
- "Smooth Level Meter" option moved out of Advanced Settings
RadioBOSS 7.2 beta
