RadioBOSS 7.2 [beta]
La mejora visual es notable, pero el punto débil está en la transmisión. Cuando necesitas obtener la dirección IP de otra emisora de radio, el búfer simplemente se congela. Probé varias configuraciones; en algunas, cargaba hasta el 91%, y en otras, al 100%, pero seguía sin reproducir. Se congelaba y tenía que cerrarlo. Esperamos con ansias una solución.
Please write in English.
It might be cleaner if all icons were shown only in the # column, without an additional Icons column.
Each file type could still have its default icon. If the user changes the icon in File Types, that custom icon would be shown in the # column instead of the default one.
But in this case, the "Scheduled" item state and played/unplayed will be lost, as all track will have their file type icons. This is the main problem.
I thought the same thing
This sounds reasonable but one question remains what to do with the "scheduled" track state, if the default icons are replaces, it would be hard to tell if an item is scheduled or not.
2. For the elements with the "played" state, the "⬆️" icon exists and it is not necessary to create a "played" state for the user-customized or default icons.
Yes, agreed.
3. For scheduled elements, the " 🕒 " icon exists. This is the most complicated one, but I believe it can be placed in a reduced space, as shown in the screenshot. Right next to the established icon and near the lower edge, separating the established icon from the "scheduled" icon.
Interesting. If the default options are changed so that played tracks have their icon, it could actually work. Drawing a small "clock" does sound like a solution, and avoids a problem of creating many states of the same icon.
4. I think it would look better to move the "Time Stretch" time and the queue number to the "numeral (#)" column. This to separate the icons from the texts.
Or the Icon column can be avoided. Currently it works like this: whatever column is the first, it gets the icons. You can try moving the column e.g. Track Title to be the first, and the icon will be there. I think this behavior should be preserved. The Icon column can be removed, being replaced by how you proposed.
Are there any error messages? What happens if you change the zoom, will it show?
There is no error message. When I zoom in, nothing happens; it still looks completely white. It happens sometimes, not always. I don't know what the reason is.
Excellent! Yes, I think it's the best solution to avoid so much work creating states for the icons.
I understand; yes, I think it's better to keep it that way. I believe a reasonable solution to the icon issue was achieved. Thank you.
One additional detail: the "▶️" icon should blink, and when paused, it should display the "⏸️" icon.
